RSV-R
Blue OZ wheels
Headers/collector
Arrow silencer
Frame inc V5
Swingarm
Lock set
Brembo gold calipers (front and rear)
Brembo front and rear discs
Heli-bars
Wiring loom
Dynojet PCIII
Evoluzione airbox kit (which seals to the tank underside)
Single seat and dual seat subframes
Front subframe (same as Tuono)
Radiators (LH & RH) Same as Tuono and Falco
Clocks
Master cylinders
Oil Cooler
Stainless oil tank
Fuel tank & bodywork (some scratches/cracks but would be good as a complete track kit)
51mm throttle bodies
ECU
LH Footrest and hanger bracket
RH Footrest and hanger bracket
RSV
Sachs white spring shock which has been serviced/rebuilt by MCT and is ready to bolt straight into a Falco with no hacking needed.
I'd be happy to put a kit together with Mille Headers, oil cooler, stainless oil tank and swingarm for a swingarm conversion for the Falco.
Falco
Brembo wheels powder-coated black
PM me if you're interested in any of the bits. They'll be going on eBay, so thought I'd give you guys first dibs. All of the above are in good/great condition except where detailed.
BenW
