What have I done now?
Dalemac
Midnight Rider
#1 Post by Dalemac » Sat Jan 28, 2012 7:23 pm
Took the falco out for a quick spin before work, im worried now because the engine temperature is all over the place, gets very hot very quickly and goes very cold when at speed. (could new coolant provide this kind of effect?)
clutch seems to have no pressure (but works ok), and is slipping every time i accelerate hard (too much adjustment on the clutch lever, probably, could also do with a quick bleed. i can actually change gear now, which is nice). is it possible that my badly adjusted lever/old fluid could have made the clutch really heavy? seems quite easy to use now....
Dale
#2 Post by mangocrazy » Sat Jan 28, 2012 7:38 pm
If you've replaced the coolant, it's odds on that you've got an air-lock somewhere in the system. Basically the system needs to be 'burped' - run it up to temperature while stationary with the radiator cap off. This allows the air pocket to circulate and escape.
Have you changed the oil, and if so, what to? And what year is your bike?
#3 Post by fastasfcuk » Sat Jan 28, 2012 7:59 pm
as mango said, if still the same check the impeller on the water pump.
#4 Post by D-Rider » Sat Jan 28, 2012 8:07 pm
Always worth squeezing all the coolant hoses while filling to burp it (or afterwards if you forgot to) - particularly the one that joins the top of the two radiators,
Dalemac
Midnight Rider
#5 Post by Dalemac » Sat Jan 28, 2012 8:13 pm
Yeah, I followed the manual and it didn't say to do that, I shall run it with the cap off tonight.
Oil wise, I put some slikolene super 4 in it, 10w40. Mine is a 2001 model.
Dale
#6 Post by D-Rider » Sat Jan 28, 2012 8:14 pm
Dalemac wrote:Yeah, I followed the manual and it didn't say to do that, I shall run it with the cap off tonight.
Dale
:smt017 Well I've just changed mine and the manual definitely said to squeeze the hoses !
Dalemac
Midnight Rider
#7 Post by Dalemac » Sat Jan 28, 2012 8:16 pm
D-Rider wrote:Always worth squeezing all the coolant hoses while filling to burp it (or afterwards if you forgot to) - particularly the one that joins the top of the two radiators,
I burped all the hoses I could find through.
#8 Post by Aladinsaneuk » Sat Jan 28, 2012 8:26 pm
Look at the diagram of the hoses and then swear about the middle connecting pipe....
Oil... Is that full synth oil .... If so.... There's the slip reason
#9 Post by D-Rider » Sat Jan 28, 2012 8:31 pm
Just noticed it doesn't mention the top one .... but it's an important one
Dalemac
Midnight Rider
#10 Post by Dalemac » Sat Jan 28, 2012 8:34 pm
Sorry, its semi synth oil. Pretty sure I have over adjusted the clutch adjuster.
#11 Post by D-Rider » Sat Jan 28, 2012 8:37 pm
No - semi according to silkolene
Edit - ah - Dale beat me to it
Dalemac
Midnight Rider
#12 Post by Dalemac » Sat Jan 28, 2012 10:34 pm
Sorry, I replied to this thread on my phone - got some things mixed up.
I squeezed all the pipes through that i could find, but didnt 'burp' the system through. Im off to do that now, as well as bleed the clutch through again. My first reply was in reference to Alad, not D-rider (took a while to post on my puny little phone)
It has to be ready for my 90 mile ride up to York tomorrow morning!
Dale
#13 Post by blinkey501 » Sun Jan 29, 2012 6:34 am
Dale if you have any more issues PM me and i will come over and look at the bike for you :smt002
Dalemac
Midnight Rider
#14 Post by Dalemac » Sun Jan 29, 2012 6:39 pm
blinkey501 wrote:Dale if you have any more issues PM me and i will come over and look at the bike for you :smt002
Not sure what good looking at it will do! thanks fot teh offer, but i have it all sorted now blinkey.
Burped the coolant through and it is back to normal now. Also adjusted the clutch adjuster, but still got a little bit of slip there, so need to take some more out. Went to overtake a few times on my 200mile round trip today and really hard acceleration caused it to slip a bit.
The go karting was good too, I came second in the 'champions race' thanks to the third place who kept ramming and spinning me, but it was ok in the end because he got disqualified for it :smt003
I got a little trophy and certificate too! yay!
Dale
