indicators only work on alarm arm/disarm?
k1w1boy
#1 Post by k1w1boy » Wed Jan 04, 2012 10:09 pm
Switch maybe?
#2 Post by Aladinsaneuk » Wed Jan 04, 2012 10:41 pm
disconnected at relay??
#3 Post by Nooj » Thu Jan 05, 2012 12:19 am
It's fucked?
Dalemac
Midnight Rider
#4 Post by Dalemac » Thu Jan 05, 2012 11:35 am
Voodo magic?
#5 Post by D-Rider » Thu Jan 05, 2012 12:13 pm
I think the switch is unlikely as for most indicator switch failures you would still have one side working correctly.
Most likely it's from the following:
  • The flasher relay
    The wire from the flasher relay to the indicator switch
    The power feed to the flasher relay
Here's a wiring diagram that you can use to highlight the circuits you wish to look at (from Martin Poll's website): http://www.martinpoll.dk/diverse/mille% ... iagram.pdf
If you want to check the flasher unit, the Workshop manual tells you how (download from Martin Poll's website): http://www.martinpoll.dk/diverse/Bikema ... 00_OCR.pdf
#6 Post by Falcopops » Thu Jan 05, 2012 12:14 pm
dodgy switch at the bars?
FlyingKiwi
#7 Post by FlyingKiwi » Thu Jan 05, 2012 12:21 pm
Have you fallen off again :smt020
k1w1boy
#8 Post by k1w1boy » Thu Jan 05, 2012 7:09 pm
FlyingKiwi wrote:Have you fallen off again :smt020
Yep Glenn...
... off my chair at the hilarity and cutting-edge currency of this jibe :smt015
k1w1boy
#9 Post by k1w1boy » Fri Jan 13, 2012 7:33 pm
Fixed! Spanner monkey ran through the obvious with no luck, then checked the wiring for that branch of the electrical system and found some 'untidy' connections to finesse, ressurecting the horn (which had failed the day after I bought the thing) in the process. However, when I went to start I got the 'fizzt-click!' and a dash reset. Turned the key off and on to a normal dash display and it started. Next port of call : replacement starter relay.
#10 Post by D-Rider » Fri Jan 13, 2012 8:22 pm
Great news Kerry
anzacinexile
#11 Post by anzacinexile » Fri Jan 13, 2012 9:22 pm
k1w1boy wrote:Next port of call : replacement starter relay.
Sounds more like battery to me. The relays passing the current because the volts are being dragged down to the point of a dash reset
#12 Post by D-Rider » Fri Jan 13, 2012 9:36 pm
Yes - agreed
k1w1boy
#13 Post by k1w1boy » Sat Jan 14, 2012 2:11 pm
The battery is one if the 'recommended here' ones and less than 2 months old
#14 Post by D-Rider » Sat Jan 14, 2012 2:17 pm
k1w1boy wrote:The battery is one if the 'recommended here' ones and less than 2 months old
Probably not that then
anzacinexile
#15 Post by anzacinexile » Sat Jan 14, 2012 8:34 pm
Unless its flat because of multiple starts at the MOT station
