Ear plugs...which ones?
#1 Post by furygan man » Tue Jun 29, 2010 1:09 pm
Can anyone recomend some really good earplugs, i'm looking for something more efective than cheap multipack sponge options as they always seem to pop out!
I'm currently getting by using closed end 'stereo' ear buds
mrapriliafalco
#2 Post by mrapriliafalco » Tue Jun 29, 2010 1:33 pm
Best I have come across cant get on with any others since using them http://cgi.ebay.co.uk/20-Pairs-MAX-1-H ... _500wt_721
FlyingKiwi
#3 Post by FlyingKiwi » Tue Jun 29, 2010 2:22 pm
These are what I use
http://cgi.ebay.co.uk/40-E-A-R-SOFT-NEO ... 19bd476341
Are you putting them in right?
Roll plug up. Use left arm over head to pull up right ear tip and insert. Hold finger on end for a minute till plug expands.
Repeat other side, Right arm to left ear tip. etc, etc.
For best results though only wear once.
#4 Post by furygan man » Tue Jun 29, 2010 4:13 pm
yeah found that post don't know whether it was here or AF1, the sponge ones i've used are from chemists so not sure it bike ones are any different but there are vairing options and everyones ear is different!
was wondering if there was any sort of rating guide as to how much sound they can filter out?
Hishy
#5 Post by Hishy » Tue Jun 29, 2010 4:16 pm
http://cgi.ebay.co.uk/40-Howard-Leight- ... 4ceefeb2c8
I use these, used to use the max but found that for some reason after a couple of hours my right ear got really painful, still get it a bit but its a lot better
mrapriliafalco
#6 Post by mrapriliafalco » Tue Jun 29, 2010 4:17 pm
The Howard Leight ones I mentioned are the only ones I have used that do not fall out my ears,spread really well and stay put
#7 Post by furygan man » Tue Jun 29, 2010 4:22 pm
thanks, now i have a starting point, at least they are cheap enough to try out! was wondering what they use in F1/Moto GP for example??
#8 Post by Samray » Tue Jun 29, 2010 4:53 pm
I think there is a question as to which sound range they cut out as opposed to how much.
#9 Post by furygan man » Tue Jun 29, 2010 4:54 pm
yeah i'm picking that up looking at the ebay stuff, still don't understand it mind!!
FlyingKiwi
#10 Post by FlyingKiwi » Tue Jun 29, 2010 4:57 pm
furygan man wrote: was wondering if there was any sort of rating guide as to how much sound they can filter out?
You need to look at the SNR figure they quote as to how much the sound level is restricted by. The higher the figure the quieter.
#11 Post by MartDude » Tue Jun 29, 2010 5:01 pm
I'm currently using GTmotoplugs, from Halfords. About £5.00 for 25 pairs. SNR 39 - 'highest rating available', or so they claim. If you moisten them slightly with spit, roll them a little, & insert them as per Flying Kiwi's post, they go in easily & don't fall out. They seem quite effective, and are fairly comfortable. If you keep them clean, and aren't too heavy-handed with the rolling, you can get away with using them 2 or even 3 times. But then, I'm from Yorkshire.[/i]
#12 Post by D-Rider » Tue Jun 29, 2010 5:44 pm
mrapriliafalco wrote:Best I have come across cant get on with any others since using them http://cgi.ebay.co.uk/20-Pairs-MAX-1-H ... _500wt_721
...... so what were you searching for when you came across these .... given the description from the Ebay link:
mrapriliafalco
#13 Post by mrapriliafalco » Tue Jun 29, 2010 6:18 pm
LOL so focused on bikes I never even saw that :smt005
Well I never
#14 Post by Falcopops » Tue Jun 29, 2010 10:08 pm
I got a set of custom made jobbies at Donnington years ago.
They fill yer lugoles with goo (and a bit of string to get it out once it sets) then send the mould off. A couple of weeks later they arrived by post.
I've found them very good and even sleep in them at rally's with no problems at all.
Cost a bit though 70 quid IIRC, but last forever.
Also I think you can get do it yourself mouding stuff now quite cheap.
If I come across the info I'll post it.
#15 Post by Viking » Tue Jun 29, 2010 10:53 pm
Similarly to FP, I got a set of custom-molded earplugs. I asked the guy what dB rating they were, and they were in the very high 30s, so pretty damned good.
You can order lots of hearing protection goodies from here:
http://www.earmold.com.au/
(Not affiliated with them in any way, shape or form. Just a happy customer.)
