Problem with Falco cutting out.
Firestarter
Twisted Firestarter
#16 Post by Firestarter » Tue Sep 16, 2008 11:25 am
Kill-switch, when cracking the throttle?
I shall not rise to the bait that D-R left in that last post :smt005
#17 Post by HowardQ » Tue Sep 16, 2008 12:54 pm
Thanks again folks, my main guess is the side stand switch, just cannot see why it now has a delay.
Nothing to do with the ride off as I start up a steep bit of hill to where it first stopped, then the next few attempts were much nearer level then level etc., and each time it would run OK in neutral, eventually ran it back down to the house in neutral and still running OK outside the garage until I killed it.
Probably get something done at the weekend, as working late on a major project at work most of this week. Will get the belly pan off, look at the side stand wiring and wire out first, then progress from there if that fails.
Cheers.................. Howard.
#18 Post by HowardQ » Mon Sep 22, 2008 12:25 pm
It turned out to be the side stand switch.
Not sure how it managed the 10 second delay before cutting out, when I tried to ride it last week. :smt017
Moved the side stand around a bit and got it so it would cut the motor instantly with the stand down.
Took it off and, being a 2001 model, it was one of the switches with the plastic pin, so did well to last this long!
Couldn't seem to find an easy way to follow the cable route and find the plug to mod the wires, so carefully filed what was left of the pin down, so it would no catch in the hole and work the rotary switch. Turned the switch to position when stand is up, and jammed it up so wouldn't easily move, then greased the face well so stand would not move it round, re-assembled and fine. probably not the best botch up, but no replacement in my spares stock, so need to order a new switch and just had to get out in that sunny weather.
Also modded the stop on the eBay side stand, (i.e ground it down a bit), so it now folds away a bit further, I have had no other problems with it,
so reckon it is a good replacement.
#19 Post by fastasfcuk » Mon Sep 22, 2008 1:41 pm
glad your sorted howard, was,nt to costly.
#20 Post by Fausto » Mon Sep 22, 2008 3:35 pm
A new switch may not be necessary.
On mine the plastic pin had disappeared. I drilled a small hole and threaded in a length of stainless bicycle spoke cut to an appropriate length. It works fine.
I have lots of spokes if you need one :smt003
#21 Post by HowardQ » Mon Sep 22, 2008 4:10 pm
I was thinkin of doing that, but struggled to find something I could use for a pin. Must admit the sun was shining and I just wanted to get out on the bike, these days I'd much rather be riding than fettling. Other problem was that I couldn't easily find the first wiring plug on the loom so never managed to disconnect the switch and take it off the bike. Not easy to try and drill when there's only a few inches of play and can't really get it into a position against something solid where it would be easy to drill.
Crap excuse I know, but as I said the sun was shining!
Will check price/availability of a new switch then might have to look at modifying with a new pin. Seem to remember they used to reasonably quick to get hold of, will check Aprilia Yorkshire and rest when I get home tonight.
#22 Post by Falcopops » Mon Sep 22, 2008 9:33 pm
HowardQ wrote:It turned out to be the side stand switch.
Damn Damn Damn
Not only is Aladinsane beating me in the Quiz he's done me on this too.
I'm not playing.
Yah Boo Sucks
:smt019
#23 Post by Aladinsaneuk » Mon Sep 22, 2008 9:46 pm
whistles as he strokes his ego
(could not have been tipover switch as the bike ran.....)
#24 Post by Falcopops » Mon Sep 22, 2008 9:52 pm
Don't patronise me you big fat pudding. :smt014
My dad's bigger than you're dad anyway. :smt019
#25 Post by Aladinsaneuk » Mon Sep 22, 2008 9:53 pm
you finally met him?
:smt005
and sorry i had to :)
