Well I've been in conversation with the chap that makes them and I can now answer just about all of the questions and uncertainties and might have some good news on the likely cost.
..... read on .....
Firstly the things people wanted:
- 1) Ethanol Resistance:
Yes, they do come with an ethanol resistant inner coating. This is what Richard says:
2) Additional Fuel Capacity: I did discuss the idea of growing the tank but that's not easy and would add to the not inconsiderable cost of the mould. However as the carbon fibre shell can be much thinner than the plastic tank, maintaining the standard external profile will inherently give a useful capacity increase (and, Graham, your Baglux tank cover will still fit). This is what Richard says:I seal them with a special base resin that is ethanol and chemical resistant. The adhesive I make to bond the base in is made using the same base resin with additives and chemicals to make it a strong ethanol resistant adhesive as you cannot actually buy an adhesive for this purpose...
Now we can't be sure how much of a capacity increase will be achieved with the Falco tank until one is made but if we assume a similar increase to the RS250, them maybe the Falco's 21 litres might climb to about 25 litres ... but, as I say, that can't yet be verified - probably safer to assume a bit less.Altering the tank to get more capacity is not easy. The mould as it is for a stock tank which is in a condition where a mould can be made directly from it is about £2500.00 if there are no logos to remove and it is not painted with anything other than 2 pack paint. The RS250 tank had been painted and the paint did react in the moulding process so needed some work to tidy up the surface a little too.. BUT having said that. The RS250 show should be 16.5 litres but because it is much thinner than the plastic used in the OEM tank it does hold about 20 litres.
3) Price: I'll come back to that in a moment - maybe not as much as you might have thought
A few more points .... the tank from which a mould can be made.
Richard points out that people generally want OEM fit of a tank that he will supply.
If the tank from which the mould is made has already suffered ethanol-related growth, then so will the mould and all the tanks that come from the mould. Therefore we need to find the best "spare" tank that we have in our various stashes of spares. I have one that I'm willing to donate to the cause. At present I'm not sure whether it has grown. I've had it empty and unused in my garage for the past five and a half years ... so it might be fairly good but if there are others out there with a good finish and that haven't grown then please let me know.
Clearly whatever we can find will have great bearing on the fit of the final product.
OK .... back to costs ......
The variables that have an impact on which we can't yet be so accurate are:
- A) The amount of carbon fibre required (or more pertinently, the amount of additional carbon fibre over and above that needed for the RS250 tank that Richard currently produces).
B) The number/cost of fittings that have to be procured and bonded in for the tank mountings, fuel-pump mountings etc.
C) The number of people who will commit in order that the mould costs can be defrayed.
Things to bear in mind:
- I) Many of us have said "I'll never sell the Falco"
II) If we fill standard tanks with fuel, the ethanol in it will make them grow and attack their very fabric .... at some point those of us that will "never sell the Falco" will have to resolve this problem.
III) Replacement genuine tanks cost between £1,200+VAT and £1,782+VAT (the cheapest being the Oasis Green and the most expensive being Grey (often referred to as Silver))
IV) The proposed carbon fibre tank will be ethanol resistant and will give us a lot more security against this cursed fluid.
V) They will have a greater capacity than standard tanks
Of course as with replacement OEM tanks, the carbon ones are just the tank shells - you need to transfer your fuel pump, filler cap, front mount etc. Look on this as a good opportunity to replace the fuel filter and internal fuel lines.
So .... the price .....
Well I'm not yet able to give you a firm price (though I do have a good indication).
What I need to know is who would be in and out at various price points.
So, please respond as accurately as possible to help me understand the viability of this. I'm collecting this information via Surveymonkey - so please click the following link and make your views known:
https://www.surveymonkey.com/r/99BFMJY
Further questions and comments? Please post them up below and we'll try to resolve them.
.... and to be going on with .... an RS250 tank
