New Falco owner in person
#91 Post by Aladinsaneuk » Fri Jan 24, 2014 5:27 pm
or you can ask an average sized falco owner to sit on the rear saddle - amazingly that small amount of added weight lifts the front end....
(I have a headstock lift that I use with the abba stand.... and I do use the attachment through the foot peg holder to allow a lot of things to be removed - I am very kind to Green Flag Staff....)
#92 Post by mangocrazy » Fri Jan 24, 2014 6:27 pm
spiderwheels wrote:While searching for a 30mm and a 32mm socket I came across this:
http://www.amazon.co.uk/Bahco-Socket-Pi ... uctDetails
Now given I was looking at a minimum of £14 just for those two socket sizes.. forking out another £33 for a whole set of quality tools didn't seem such a bad idea.. Although I am getting worried I'm buying tools like some people buy shoes..
They are a couple of quid cheaper at My Tool Shed:
http://www.my-tool-shed.co.uk/p19658/Ba ... _info.html
I know 'cos I've just bought a set! At that price it seemed rude not to. But postage will probably even up the difference for you. I bought some other stuff and got it up to the amount needed for free postage. Which probably made the socket set slightly less of a bargain, I suppose...
#93 Post by mangocrazy » Fri Jan 24, 2014 6:30 pm
plasticpig72 wrote:Just because my bike came fitted with technoflex front and rear, they seem exceptionally good, just wondered how they compared.
Everything I've heard says they're on a par with Ohlins, which seems to be borne out by your experience.
#94 Post by D-Rider » Fri Jan 24, 2014 6:43 pm
Well I don't actually need a new 1/2" drive set ..... though a socket from the set I've had for about 40 did split last year and the ratchet broke (though I have bought a new one) ..... but I have got some amazon vouchers that I haven't got a plan for ....
I might end up persuading myself ....
#95 Post by fatboy » Fri Jan 24, 2014 7:31 pm
I got a 1/2 inch drive deep impact socket set, slim pattern from Amazon for just under £30.
10 to 32mm (all main sizes in that range), very handy kit, still on there but search for impact sockets
#96 Post by mangocrazy » Fri Jan 24, 2014 8:54 pm
I'm a big fan of Bahco stuff. I also have the 1/4" drive set, the SL25:
http://www.buybrandtools.com/acatalog/b ... tAodHVYAyg
It's been an absolutely cracking little socket set and gets used all the time. If the 1/2" drive set is as good as the little 'un (and I have no reason to believe it won't be), then I'll be very pleased.
What they don't show you on the photos of the 1/2" drive set is that theres a clip-in lid that separates the socket side of the set from the extension bar side, and stops the sockets falling out and rearranging themselves when you carry the set around. They also have a little nut/odds and ends holder incorporated in the carry case. It's little attention to detail like this that means a lot in daily use.
#97 Post by Aladinsaneuk » Fri Jan 24, 2014 9:17 pm
The bahco 1/2 set is good - I have had one for several years!
I bought it after I got the 1/4 set - very impressed
#98 Post by D-Rider » Fri Jan 24, 2014 9:35 pm
A great little 1/4" drive set that I've got is this one:
Teng Tools T1419
http://www.automotive-toolzone.co.uk/ha ... t-1-4.html
Tiny little set, easily fits in your pocket.
It's not as extensive as the one Mango posted up but the size and quality is brilliant.
The price was good .... got it free when I took out a subscription to Lead Magazine (well I think it must be called "Lead" as it has "Pb" written on the cover)
#99 Post by mangocrazy » Fri Jan 24, 2014 10:20 pm
Yes, Teng Tools are good gear, as well. With the Bahco 1/4" set I've added a few bits to it - a knuckle joint and PZ1, PZ2, PZ3 and flat head screwdriver bits. They all fit inside the case and it makes for a compact but comprehensive set.
GregD-UK
Tools...
#100 Post by GregD-UK » Sat Jan 25, 2014 5:30 pm
Have bahco adjusters for work. But, have some sexy wera 1/4 inch socket and bit set for the bike :smt007 German swag very good...
#101 Post by mangocrazy » Sat Jan 25, 2014 6:49 pm
Yes, Wera are THE name when it cmes to screwdriver bits. I've got Wera bits in my 1/4" set.
#102 Post by D-Rider » Sat Jan 25, 2014 8:07 pm
mangocrazy wrote:Yes, Wera are THE name when it cmes to screwdriver bits. I've got Wera bits in my 1/4" set.
I think I must have a lot of their tools . I'm forever asking "wera the sockets?", "wera the screwdrivers?", "wera the pliers?" etc etc etc
spiderwheels
#103 Post by spiderwheels » Sun Jan 26, 2014 10:03 am
D-Rider wrote: I think I must have a lot of their tools . I'm forever asking "wera the sockets?", "wera the screwdrivers?", "wera the pliers?" etc etc etc
They make keys too... :smt013 :smt013
