How Fast Is Yours?
NickyT
How Fast Is Yours?
#1 Post by NickyT » Sun Jul 21, 2013 11:11 am
Mine has a K&N filter with Evo air kit, Forza chip, GPR cans, 1-tooth smaller front sprocket.
Was out very early this morning so thought I'd hold it open for a while. Past 135 or so it was accelerating really slowly. Past 140 and the speedo was crawling.
I thought it'd be faster. The fact that I've owned the bike for a year and have only just noticed goes to show that top speed is irrelevant even when you do track days, but still I thought it would breeze its way into the 150s before the rate of acceleration decreased rapidly.
#2 Post by Aladinsaneuk » Sun Jul 21, 2013 11:28 am
The gearing change is the probable reason why?
zoidberg
#3 Post by zoidberg » Sun Jul 21, 2013 11:49 am
And now you're selling it?
Unless you track riding a lot I wouldnt worry about it. It's plenty quick enough for the road !!
#4 Post by D-Rider » Sun Jul 21, 2013 2:02 pm
Posting speeds on an open forum ..... never a good idea ......
Even allowing for the fact that you are "obviously posting in kph":smt002, they're still high enough to get you into bother.
.... and as zoidberg has alluded to, having posted in the Items for Sale section, are you actually selling anything?
Cathcart
#5 Post by Cathcart » Sun Jul 21, 2013 2:34 pm
I've got a similar setup 15/42 gearing with forza, k&n and cans. Mine happily steams up to 145mph before reaching a slower increase. Never had the urge to check exactly how fast ... you are tucked away nicely?
Obviously the speeds I state from here on in are complete lies and I'm just trying to pretend I go over 70 to look super cool...
Marco Simoncelli.
#6 Post by fatboy » Sun Jul 21, 2013 6:18 pm
Silly boys, remember any kind of speed evaluation is always done ON THE UN USED AIR FEILD near where you live.
Yes, that one, you remember it now dont you !
#7 Post by blinkey501 » Sun Jul 21, 2013 6:40 pm
In standard form they should do 160. A bit too fast for my blood. :smt104
#8 Post by HisNibbs » Sun Jul 21, 2013 7:14 pm
Fast enough :smt002
#9 Post by Falcopops » Mon Jul 22, 2013 12:28 am
With the gearing down you're obviously going to knock off the top speed.
I've got 2 extra teeth in the back sprocket, so not much different to yours, I've found that keeping it in 5th will help at the top end and rev it right out before changing up, keep everything tucked in. The disused airstrip I was using had a couple of potholes and grassy tufts that I had to steer round and I topped out at 258kph, there was a slight decline on the latter part of the airfield though.
#10 Post by D-Rider » Mon Jul 22, 2013 12:48 am
Falcopops wrote:With the gearing down you're obviously going to knock off the top speed.
From what I've heard, that's not actually the case as the bike cannot pull the standard gearing to max revs in 6th.
By all accounts 15/41 gives you the same real-world top end (if you can find anywhere to use it) but helps you get there more easily.
#11 Post by flatlander » Tue Jul 23, 2013 10:28 pm
mine is incAPble of exceeding the speed limit as is the rider :smt018 :smt059
at least since the last 3 speed courses and getting stopped again :smt010
Cathcart
#12 Post by Cathcart » Wed Jul 24, 2013 9:47 am
This is true. There does come a point where down gearing lowers your top speed, but changing it slightly does infact usually give a higher real speed.
Marco Simoncelli.
