including the spacers..
Alad will probably be along with an idea.. he's whipped his in and out a few times..
I got sick of my spacer dropping out, so stuck it to the bearing with a dab of silicone sealant. It doesn't drop out any more...bigun wrote:Take the wheel out and pop the sprocket/carrier off. There should be quite a big spacer on the rear of the carrier too. I don't think it'll make any difference to what you're experiencing if it is missing but it'd be worth checking just in case (I nearly forgot to put mine back in yesterday!)
Right further examination. You will see from the pics that one of the carrier bearings is screwed completely. The is no spacer behind the carrier just the one in the pic at the front of the carrier.mangocrazy wrote:I got sick of my spacer dropping out, so stuck it to the bearing with a dab of silicone sealant. It doesn't drop out any more...bigun wrote:Take the wheel out and pop the sprocket/carrier off. There should be quite a big spacer on the rear of the carrier too. I don't think it'll make any difference to what you're experiencing if it is missing but it'd be worth checking just in case (I nearly forgot to put mine back in yesterday!)
I've tracked down another spindle and carrier off fleabay, it can't be any worse than mine. Thanks for everyone's input. I have a sneaky suspicion this will not be the last of my problems.mangocrazy wrote:That looks horrible - sorry. I can see so many things wrong there it really isn't funny. Let's see...
1. It looks like an inner bearing race has welded itself to the wheel spindle at some point. I'd be looking for a new wheel spindle on eBlag, if I was you.
2. The sprocket carrier bearings should be the 2RS type; i.e 2 Rubber Seals, one on each side (obviously). The inner bearing in your pic looks shot to hell and has no rubber seal.
3. There should be two bearings and both should have sleeves on the face closest to the wheel. I can only see one bearing in your pic, although that may be me mis-reading the pic. This fiche from Ultimate parts shows how the sprocket carrier bearings should look:
https://www.ultimateparts.net/aprilia/c ... EM&i=18436
Note that there are two off parts numbers 23 and 24 in the sprocket carrier. Is yours like that? Frankly, I doubt it.
As it happens I've just done all this stuff on my sprocket carrier, so it's fresh in the memory.
Got a phone call from a friend of mine to say someone he know is breaking a falco it's an 01 plate with 12k miles. He's sold the engine for £300 and the almost new blue flame exhausts for £100 but the rest is available if anyone is interested, I can let you have his number.Aladinsaneuk wrote:will look tonight - PM me your mobile number or email address and i will photo what i have
