Renegade Hi Level Exhausts
Cathcart
#61 Post by Cathcart » Mon Feb 04, 2013 9:08 pm
www.apriliaforum.com/forums/showthread. ... hlight=box
Halfway down is the one I was talking about, possibly the same one as the young chap above is meaning.
Marco Simoncelli.
#62 Post by Aladinsaneuk » Mon Feb 04, 2013 9:19 pm
The +10 chip is I believe a code for 1 degree ignition change
It was for the small valve rotax engines
The +20 chip had the same ignition change but was for the larger valve engines
falcomunky
#63 Post by falcomunky » Mon Feb 04, 2013 9:50 pm
'Young chap'!?!? :smt006
Those pics are pretty much what my Bro has done, except he's used the front end of the AB upper half to hold the filter in place too. It kinda cups up n over the front two-thirds of his K&N if that makes sense? :smt017
If I can get the car door seals in the next day or two, then I'll have it done this week as I'm off work and yes: Pics will be taken! lol (I aint done a 'How To' since I swapped my swingarm a few years back mind...)
Slightly off-track but: These will fit the Falco wont they?.....
http://www.ebay.co.uk/itm/PAIR-OF-998-9 ... 19d8773435
Its just mine have pitted-pistons (partial seize on the front right this afternoon: NOT fun!) so its either get em refurbed or buy another pair taking the risk they are in good nick...
Two is the magic number... ;)
#64 Post by D-Rider » Mon Feb 04, 2013 10:02 pm
Aladinsaneuk wrote:The +10 chip is I believe a code for 1 degree ignition change
So what's the +2 chip then?
(I know that the answer to this and the others, come to that, is unknown - despite all attempts to find out)
1 degree of advance on the +10 doesn't sound like much TBH
Never heard of the +20 before
#65 Post by Aladinsaneuk » Mon Feb 04, 2013 10:15 pm
renegade chips were labelled in a very professional and scientific way..... a sticky label and either a dot matrix printer or more commonly, in my experience, a written code
i believe that +1 and +10 are interchangeable terms - same for +2 and +20 - probably down to who was doing the writing that day!
tim has iirc a +20 chip.....
i used the descriptor of +1 degree as a rough guide - i do not know the exact figure though i believe it was about 2 or 3 degrees ish
Tim has been trying to track down jorge's chip guru - to no avail :(....
bigun
AP RS Legend
#66 Post by bigun » Mon Feb 04, 2013 10:24 pm
Cathcart wrote:There's a good write up floating about somewhere on this site with the air box chop. It's a cracking job the guy had done. Used a little off the front of his air box lid to hold the filter in place and for a better seal as far as memory serves...
If it is the one I'm thinking about, I bought it off the lad who made it and its been on my Mille for 2 years. Beautifully well done mod. If you want photos let me know and I'll get some tomorrow night.
Edit - in fact, found the original post the lad did - http://www.apriliaforum.com/forums/show ... +mod+Mille
Bigun
#67 Post by mangocrazy » Mon Feb 04, 2013 10:32 pm
falcomunky wrote:Slightly off-track but: These will fit the Falco wont they?.....
Those are exactly the same as the OE Falco fitment - 65mm between bolt centres. The ones you have to be careful of are the 40mm between centres fitting. Those are Ducati only AFAIK.
falcomunky
#68 Post by falcomunky » Mon Feb 04, 2013 11:05 pm
Cheers mangocrazy: I thought they were the same. :smt004
Cheers bigun: In my trawls of t'internet I hadnt found that write-up! Like the look of it too so might ape that one rather than my Bros (same basic idea though) :smt005
Still need a chip mind..... :smt002
#69 Post by D-Rider » Tue Feb 05, 2013 12:50 am
Aladinsaneuk wrote: i believe that +1 and +10 are interchangeable terms - same for +2 and +20 - probably down to who was doing the writing that day!
From earlier in this thread ......
Kwackerz wrote:I was hoping that one (as in the chip..) might get raped and have twins... or quadruplets
*stares with suggestion*
I have a feeling that a Rene C is the same as a +2
..which is what I have..
*edited for the nurse*
As I say, I've never heard of a +20 ...... maybe you dreamed this one up after falling asleep having eaten some special cheese :smt003
#70 Post by Aladinsaneuk » Tue Feb 05, 2013 6:04 am
I think I read about the +20 chip on the old rsvrzone, aft and the original rsvr.net - and it was nick, the south african guy who used to own rsvr.net that offered me a +20 chip at the club aprilia open day at the england's rose pub... it was in a box and definitely was marked +20... I had not long had the falco then and was just starting to find out about them... that was the first time I had heard of renegade!
#71 Post by mangocrazy » Tue Feb 05, 2013 9:27 am
It does all smack of amplifiers with a volume control that goes to 11, doesn't it...? :smt003
falcomunky
#72 Post by falcomunky » Tue Feb 05, 2013 10:46 am
lol! :smt005 My amp does that... :smt002
Still with the airbox mod: Which of these two profiles would, in the sites collective mechanical knowledge, be most suitable?
http://www.ebay.co.uk/itm/Car-Boot-Door ... 5873205%26
http://www.ebay.co.uk/itm/Universal-Jum ... 5873205%26
Notice how the first link profile stands up near-vertical while the second is more of a horizontal profile. The link you posted bigun(showing the Mille AB mod) has the latter horizontal style. I assume that the Falco tank differs from the Mille tank underneath (as it does up-top) so anyone know if that means one profile works for the Mille, the other for the Falco?... :smt017
Need to get all this worked out before I fire-up the Dremel (I only have one AB!)...
Cathcart
#73 Post by Cathcart » Tue Feb 05, 2013 2:38 pm
I'm thinking about ordering the top one... Reason being, I'm sure the seal is to stick out as opposed to up on the bottom of the air box. With the top one I'm thinking it'll be possible to hook it onto the lip with some form of sealant and fixings. I could be wrong though as I've not done this mod yet.
Marco Simoncelli.
falcomunky
#74 Post by falcomunky » Tue Feb 05, 2013 2:47 pm
Well, I've gone with the bottom profile :smt016
Only reason being is that when I used the oh-so-technical 'fingers up between the tank and airbox' method of measuring, (yes, I have long-fingered ladies-hands lol) it felt like there was more space on the vertical than on the horizontal. My thinking being that its more likely to achieve an air tight seal across the smaller, horizontal gap, as well as give an extra couple of cc's capacity! :smt002
I'll hopefully have it all done by the end of this week, (assuming the seal comes in the next day or two) and report back with pics/links etc... :smt006
#75 Post by Aladinsaneuk » Tue Feb 05, 2013 3:21 pm
definitly the horizontal plane - at about a 45 degree angle like the evo design
the sealant you should use is vaseline btw
