Jangly front end
ReggieGasket
Jangly front end
#1 Post by ReggieGasket » Sun May 02, 2010 6:26 am
I've managed to get a few miles in so far this year and it's official - the front end is too jangly. I seem to pick up lots of bumps even on the motorway. The previous owner had the forks done by Maxton. I suspect the front set up is for a heavier person than me - he was a bit larger. The forks may work well on the track, but I like a soft set up on the road. I've backed the pre-load and damping right off. Maybe I need to try them up a bit. Any thoughts?
sabestian
#2 Post by sabestian » Sun May 02, 2010 7:34 am
Is the SAG right for you?
ReggieGasket
#3 Post by ReggieGasket » Sun May 02, 2010 1:36 pm
I thin the main problem seems to be too much stiction (is that a word?). When you press gently but firmly the forks stick more than they should. I'm hoping this is becuase the fork oil needs changing. Any views?
#4 Post by Kwackerz » Sun May 02, 2010 1:55 pm
http://www.diracdelta.co.uk/science/sou ... ource.html
Yes, Its a word... spot on as it happens
ReggieGasket
#5 Post by ReggieGasket » Sun May 02, 2010 7:26 pm
Monkey. So how do I get rid of it?!
#6 Post by HisNibbs » Sun May 02, 2010 9:01 pm
If you have sticktion then the first thing I'd check is that the forks aren't binding.
Slacken the axel nut off a little , loosen the axel clamps. Bounce the forks up and down on the front brake and re tighten.
By all means if its never been changed to your knowledge then change the fork too.
ReggieGasket
#7 Post by ReggieGasket » Mon May 03, 2010 7:44 pm
Good idea. It's possible I'm not fitting the front wheel correctly too. Is there a correct process?
#8 Post by Nooj » Mon May 03, 2010 8:03 pm
Sticktion = Static Friction. Check your fork seals. Are the fork legs bent? inners and outers can bend so check both. Are the forks aligned properly/twisted in the yokes? Are the damping shims sticking closed in old lumpy fork oil? Maybe even have a look at the internal bushes if it really feels sticky and nothing else comes to light.
ReggieGasket
#9 Post by ReggieGasket » Fri May 07, 2010 8:13 am
Have followed the advice of HisNibbs and that has helped. Thanks mate. I've also increased the damping and that also has helped a bit. I think the spring is still too hard, but there's nothing I can do about that right now.
