cylider sync
cylider sync
#1 Post by fastasfcuk » Mon Dec 28, 2009 4:48 pm
quick question, griff informed me mine were out so as any body done this themselfs and whats the best tool for the job. if it's not an easy job i'll get griff to do it for me. thanks.
#2 Post by D-Rider » Mon Dec 28, 2009 5:49 pm
Yep ... (I'm assuming that you mean synching the throttle bodies)
I use a carbtune to do mine
http://www.carbtune.com/
#3 Post by fastasfcuk » Mon Dec 28, 2009 6:41 pm
thanks andy.how often do you need to do this.
GregD-UK
Carb sync...
#4 Post by GregD-UK » Mon Dec 28, 2009 7:32 pm
OK, I am interested in the time scale on this also :smt002 How often and how do you know they are out :smt017
#5 Post by D-Rider » Mon Dec 28, 2009 9:14 pm
The workshop manual tells you to check and adjust if necessary every 12months or 4687miles (ie every service).
The workshop manual also tells you how to do this. Note that few of us have the really early bikes that require the adapters to be put beneath the TBs in order to connect the vacuum lines - most of our bikes have the necessary connection points on the TBs.
GregD-UK
TB's
#6 Post by GregD-UK » Mon Dec 28, 2009 9:38 pm
OK D-R, have you got a pic so I know what I am looking for pwetty pweasz :smt003 Which year bike has the "T" connections on?
Cheers.
#7 Post by D-Rider » Mon Dec 28, 2009 10:02 pm
No pics - sorry - and I'm not freezing my nuts off tonight to take some .... maybe tomorrow if I've time.
I think it was only the very early bikes that needed the adapters.
Falken
#8 Post by Falken » Tue Dec 29, 2009 9:51 am
:smt001
I've got an Aprilia synch tune somewhere, but never used it.
I'll have a look when i get home if anyone wants to borrow it, i'll post it if you'll send it back.
Or deliver it if your close by.
Adventure before Dementia.
GregD-UK
TB's
#9 Post by GregD-UK » Tue Dec 29, 2009 10:31 am
Woops! D-R I have a Jan 2002 Black (Fast one) by the way :smt003 It is tucked up in own ickle garage with the radiator on :smt002 Flippin freezing up here as well....
Thanks for the offer Falken :smt003
Might go down the buying route if it needs to be done every year!
Re: Carb sync...
#10 Post by fastasfcuk » Tue Dec 29, 2009 3:49 pm
GregD-UK wrote:Hi all,
griff new mine were out just by listening, but that comes with experiance.i had noticed that my tick over was sometimes at 500 rpm and other times at 1000rpm which he said was a sign.
#11 Post by D-Rider » Tue Dec 29, 2009 5:22 pm
Well I didn't manage to get out to take some pictures of the bike but I remembered that the vacuum gauges (carbtune in my case) attach to the same things that you use to get the vacuum control of a scottoiler .... and that there is a picture of that on their website.
In the picture you will see a black plastic boot with a black tube coming out of it - this is the scottoiler vacuum connector. The plastic boot is pushed on to a metal tube that comes out of one of the throttle bodies. This is where you connect one of your vacuum gauges. Obviously if you have a scottoiler fitted, that must be temporarily disconnected.
The other throttle body has a similar tube coming out of it - but on the other side of the bike ... connect another vacuum gauge to this.
If you don't have these tubes coming out of the throttle bodies then you have an old bike and you need the adapters that fit beneath the throttle bodies .... or pick up a set of throttle bodies from a newer bike ......
Re: Carb sync...
#12 Post by D-Rider » Tue Dec 29, 2009 5:24 pm
Yes - tickover won't be as smooth and low (engine) speed running with small throttle openings will be much more lumpy.
#13 Post by Aladinsaneuk » Tue Dec 29, 2009 5:28 pm
of course some of us have merely replaced the throttle with an on/off switch but.....
