Buggered my clutch
Buggered my clutch
Managed to do the following jobs over a few evenings in the past couple of weeks:
Fit new front brake light switch
Clean zebra strip in speedo LCD
Strip and clean front calipers
Replace spark plugs
Change oil and filter
Inspect clutch diaphragm for leaks and inspect clutch for wear.
Took it out for the first time today and the clutch is slipping at anything more than a whiff of throttle. I didn't touch the hydraulics and I put all the parts back in that I took out - it's hardly rocket science. But did I miss a trick somewhere along the line?
Replace spark plugs
Insert humourous comment here
Check you have some free play at the clutch lever, if not the pushrod is engaging and you will have slipping.
Make sure the operation feels smooth, the pushrod is not snagging.
Sone models have o tooth missing on a plain plate,this goes in first, if you have a friction plate with a coloured tab this goes in last, offset, it sits in a shallow groove.
If your spring bolts are not tight enough,this will cause clutch slip
- flatlander
What oil did you use certain oils can cause some slipping I believe depending on year
That's probably what I've done. In too much of a rush to get it back together..HisNibbs wrote:Be very careful to get the plates in the basket properly. I think it is quite easy for the top plate to catch on the outside edge of the basket stopping your clutch from working properly.
- Firestarter
- Twisted Firestarter
