Cam chain tensioner service
My falco has distinct rattle, I believe it's the cam chain tensioner because I've checked the shims and there within range!
I understand the cam chain tensioner is hydraulic self adjusting, but Is there a way in which to test it's effectiveness?
My first thoughts were just to remove the valve covers and turn the engine over on the starter to observe the operation of the tensioners but I'm unsure if this is wise as I mave get oil everywhere!
Can someone point me in the right direction, a simple what to check for and where to observe would be awesome :)
blinkey501 wrote:Not sure about the tensioner. but if your worried about getting oil everywhere, remove the plug caps so the bike won't start?
LOL that's a good one Jay
(just in case anyone hasn't twigged this one, if it doesn't start you'll get no oil pressure so the hydraulic tensioners won't operate)
Back to the question - no direct experience of this but I do recall reading about it somewhere ..... might have been on AF1.
Really? So with the engine turning over the oil pump doesn't work?D-Rider wrote:blinkey501 wrote:Not sure about the tensioner. but if your worried about getting oil everywhere, remove the plug caps so the bike won't start?![]()
I think the joke is on you mate.
Yes you will get some oil pressure just turning over BUT will this be sufficient pressure to operate the tensioners ?
May be worth noting that on starting the oil pressure is initially high because of the viscosity of cold oil, then pressure drops as it warms so by the time you're ready to put your lid on you may hear some chain rattle.
Cover the end cans with a bit of rag, pic the rpm up to 2000 and see if you can still hear said rattle ( at working temp )
Most unlikely - though if it did, you'd still get oil everywherefatboy wrote:Yes you will get some oil pressure just turning over BUT will this be sufficient pressure to operate the tensioners ?
When I replaced my tensioners I didn't know you should prime them with oil before installing them into the engine - so there was absolutely on oil in the tensioners and it sounded horrible. I ended up turning the engine over without a spark plug in each cylinder (didn't know this was bad on a falco at the time) and after a a couple of turns the tensioners primed up and bad sounds went away.
So yes, there is definitely enough oil pressure to prime the tensioners just by turning the engine over.
- randomsquid
- Wear the Fox Hat
Mine rustles rather than rattles. Then again I'm typically at 4k revs or higher. It is a bit clanky if you open it up from low revs.blinkey501 wrote:These engines do rattle though mate.Yellowperil wrote:I notice the sound more a low rpm but I get a lot more rattle when I try to pull away from 2'500 so could this be slack cam chains or just a typical loaded engine rattle!
Dear in mind the manual specifically warns to change down before rapid acceleration ;)randomsquid wrote:Mine rustles rather than rattles. Then again I'm typically at 4k revs or higher. It is a bit clanky if you open it up from low revs.blinkey501 wrote:These engines do rattle though mate.Yellowperil wrote:I notice the sound more a low rpm but I get a lot more rattle when I try to pull away from 2'500 so could this be slack cam chains or just a typical loaded engine rattle!
Replacing the tensioners isn't especially hard, its just a bit fiddly. You would need an extendable socket set and some universal joints.
