Grease for my ring?
Grease for my ring?
#1 Post by MartDude » Wed Nov 21, 2012 1:28 pm
Injector o-rings, that is. On the BMW K100.
Would silicone grease be ok? If not, what else?
#2 Post by MartDude » Wed Nov 21, 2012 2:56 pm
I did a fairly extensive Google search on this before posting - looked at quite a number of threads on (mainly) car,bike & boat forums. There seems to be 2 principal schools of thought on this: use silicone grease, petroleum-based products can cause o-rings to swell; and, use clean engine oil/grease, silicone can damage o-rings. Not being an expert on lubricants and their effects on different materials, I'm still in the dark.
slickliner6
#3 Post by slickliner6 » Wed Nov 21, 2012 3:24 pm
maybe a little off topic but,,,,,,,,,
when we used to use the old copper slip at work it was found to cause o-rings to harden and become brittle.
we were so poor when i was growing up.Dad said "its a good job i was born a boy,at least id have something to play with" ;-)
#4 Post by randomsquid » Wed Nov 21, 2012 4:15 pm
Dunno but kawasaki specify silicon grease for the sliding (occasionally) bits of my callipers. That's steel pins sliding in rubber gaiters. You can get big tubes from industrial supply places like RS components for about the same price as tiny amounts from car accessory places.
#5 Post by blinkey501 » Wed Nov 21, 2012 5:27 pm
http://www.wynns.co.za/greases.htm
We use this when building pneumatic valves up mart on the o rings it is a lithium type grease. It should be more than adequate
#6 Post by Willopotomas » Wed Nov 21, 2012 7:01 pm
I use red rubber seal grease. The same stuff ye use when doing fork seals etc.
http://www.opieoils.co.uk/p-999-fuchs-r ... omers.aspx
#7 Post by MartDude » Wed Nov 21, 2012 7:38 pm
Is that sufficiently heat resistant for injector o-rings, Will?
#8 Post by mangocrazy » Wed Nov 21, 2012 7:56 pm
Another vote for red rubber grease here. It's de rigeur when reassembling brake calipers. Brakes can get pretty damn hot, as well...
#9 Post by fatboy » Wed Nov 21, 2012 8:44 pm
Martdude, you only need the lube for ease of assembley,
red rubber grease wont hurt any seal at all (modern grease is white )
Wait for interjection re Canadian weilding big club.
Next time you need to think about the injector seals, it will be time to replace em
#10 Post by Willopotomas » Wed Nov 21, 2012 10:23 pm
MartDude wrote:Is that sufficiently heat resistant for injector o-rings, Will?
Well my K100 is still going after feck knows how many thousands of miles since clearing them out. Had the bike 10 years, must've covered a good 40-50,000 miles since. Ah, back in the times when I only rode my bike all day.. *sigh*
