Grease for my ring?
Grease for my ring?
Injector o-rings, that is. On the BMW K100.
Would silicone grease be ok? If not, what else?
I did a fairly extensive Google search on this before posting - looked at quite a number of threads on (mainly) car,bike & boat forums. There seems to be 2 principal schools of thought on this: use silicone grease, petroleum-based products can cause o-rings to swell; and, use clean engine oil/grease, silicone can damage o-rings. Not being an expert on lubricants and their effects on different materials, I'm still in the dark.
- slickliner6
maybe a little off topic but,,,,,,,,,
when we used to use the old copper slip at work it was found to cause o-rings to harden and become brittle.
A day without a laugh is a day wasted.
we were so poor when i was growing up.Dad said "its a good job i was born a boy,at least id have something to play with"
- randomsquid
- Wear the Fox Hat
Dunno but kawasaki specify silicon grease for the sliding (occasionally) bits of my callipers. That's steel pins sliding in rubber gaiters. You can get big tubes from industrial supply places like RS components for about the same price as tiny amounts from car accessory places.
- blinkey501
http://www.wynns.co.za/greases.htm
We use this when building pneumatic valves up mart on the o rings it is a lithium type grease. It should be more than adequate
- Willopotomas
- GP Racer
I use red rubber seal grease. The same stuff ye use when doing fork seals etc.
http://www.opieoils.co.uk/p-999-fuchs-r ... omers.aspx
- Willopotomas
- GP Racer
Well my K100 is still going after feck knows how many thousands of miles since clearing them out. Had the bike 10 years, must've covered a good 40-50,000 miles since. Ah, back in the times when I only rode my bike all day.. *sigh*MartDude wrote:Is that sufficiently heat resistant for injector o-rings, Will?
