Make your first post here!
SL,STEVE
#31
by SL,STEVE » Thu Jun 27, 2013 5:04 pm
slickliner6 wrote:Ello from across the border.
Pint of twat for me cheers.
And a friendly hello back from down south!
Of course you dont look fat on a Falco!
#32
by fatboy » Thu Jun 27, 2013 5:24 pm
Try to establish if you are getting a fuel supply. Sounds like the pump is priming but if one of the injector relay's has died then it will not start.
Under the tank on the LHS is the return line with a Quick Dissconnect coupling, undo this and crank it over, you should get a fair bit of petrol over your hand !
If no fuel in the return line,suspect injector relays, test using an LED test light or NOID light plugged into the injector connecting thingy, you should get a bright constant pulse from the test rig when cranking it over.
Had a similar problem, fuel punk spanked but primed up ok, just would not work under load
#33
by blinkey501 » Thu Jun 27, 2013 5:36 pm
Silly question I know but... Have you put any oil in the oil tank?
SL,STEVE
#34
by SL,STEVE » Fri Jun 28, 2013 5:37 am
blinkey501 wrote:Silly question I know but... Have you put any oil in the oil tank?
When I first bought the bike, I noticed it was a little low on oil so I did put some in to bring it to the correct level.
#35
by Aladinsaneuk » Fri Jun 28, 2013 6:27 am
oh oh.....
I think we have our winner
oil in these rotax engines is not like on an inline 4
Please tell me that you did not top up the oil to a mid point on the sight glass on a cold engine?
if so, we know the problem - second one this year
I will wander over today and have a look and I am willing to bet that we will find an airbox full of oil..... clean that out and the bike will start
#36
by Willopotomas » Fri Jun 28, 2013 8:53 am
Read the above, and this popped in to my head.
#37
by D-Rider » Fri Jun 28, 2013 9:08 am
Ah ..... another case of RTFM !
Still, should hopefully be an easy one to fix
#38
by Aladinsaneuk » Fri Jun 28, 2013 1:05 pm
and ...
that wasn't it
there was some oil, but not enough to cause none starting
we do have spark and we do seem to have fuel pump initiating
what we don't have is fuel getting from the tank to the throttle bodies....
Steve told me that the bike just stopped - no warning - though the fuel light had been on for a couple of days
I suspect that the fuel filter is totally blocked - so on Monday we will have a look at that
#39
by D-Rider » Fri Jun 28, 2013 1:45 pm
Yep - I had been thinking that might be the case but was waiting for a bit more news before suggesting opening the tank and then trying to re-seal it.
#40
by mangocrazy » Fri Jun 28, 2013 6:15 pm
It might also be worth remembering the really difficult to track down issue that has affected a few fuel pumps where the internal wiring has broken... That caused huge amounts of head scratching I recall...
#41
by fatboy » Fri Jun 28, 2013 6:25 pm
Worth mentioning yet again, check for full voltage into and out of fuel pump relay,then check injector relays, the input side of the injector relays are silver coloured, the output copper coloured, with a proven voltage, the injector relay should instantly switch to full voltage to the output side, and, there are no surplus connectors under the LHS tail unit where the relays hide.
Component failure is impossible to predict, then apply The Law of Sod !
SL,STEVE
#42
by SL,STEVE » Sat Jun 29, 2013 5:27 am
A massive thank you to Aladinsaneuk who was good enough to take up his time to come assist in trying to get my bike sorted. Top bloke!!
#43
by D-Rider » Sat Jun 29, 2013 8:51 am
SL,STEVE wrote:A massive thank you to Aladinsaneuk who was good enough to take up his time to come assist in trying to get my bike sorted.
Hmm ....... I wonder who he got to come in his place
SL,STEVE wrote:Top bloke!!
we've met him
#44
by Aladinsaneuk » Sat Jun 29, 2013 9:03 am
Ok Noah - haven't you got a meet to attend? They all have their waterproofs ready
#45
by D-Rider » Sat Jun 29, 2013 9:05 am
Nah ..... picking up a few hard-to-obtain Falco parts today
