Useless Italian lump of crap!
#16 Post by fatboy » Sun Apr 28, 2013 6:58 pm
As D-Rider says,check ALL connections.
A shitty pos or neg connection on any part of the starting circuit will give you shagged battery/starter motor like symptoms
old git
#17 Post by old git » Sun Apr 28, 2013 7:08 pm
Also check the connection down at the starter motor, don't think many venture down there often and rusty old connection at the starter won't help either.
Good luck
#18 Post by randomsquid » Sun Apr 28, 2013 9:28 pm
nicketynoo wrote:
did any falco's come with a light on/off selector switch cos mine are always on. I always ride with them on but would like to be able to switch off for starting.
Mine's a late brown one and it came without the switch.
I changed the switchgear and it definitely made a difference to starting.
It's a straight swap but you have to pull the fairing off to get at the plug, which to be honest isn't a big job.
Far as I could see when I was doing mine there are three types of switchgear. The one that you have with the blanked off switch. There is one the same but with the switch intact. Then there are the older ones with the silver indicator switch. These have the indicators in the normal place in the middle rather than at the bottom.
Bought mine off here from someone who wanted the indicator switch in the normal position so it looks like all types use the same multiplug.
nicketynoo
#19 Post by nicketynoo » Mon Apr 29, 2013 1:03 pm
ReggieGasket wrote:If all you needed was a new battery, you'll owe your bike and the Italian nation an appology :smt003
Actually in my defence your honour I was only asking if this was the correct way to address your Falco if it didn't start!. I never once stated that these were the actual words used at the time. Think I could get away scott free on a technicality :smt003
I don't care if you lick windows,
Take the special bus
Or occasionally pee on yourself.
You hang in there sunshine, you're special!
#20 Post by Aladinsaneuk » Mon Apr 29, 2013 1:20 pm
nah
get the matches - burn the heretic
#21 Post by fatboy » Mon Apr 29, 2013 8:14 pm
Hah, dis believer, have fire lighters in the boot of the car.
SimonDk
Re: Useless Italian lump of crap!
#22 Post by SimonDk » Mon Apr 29, 2013 8:29 pm
nicketynoo wrote:Useless Italian lump of crap!
Is this the correct way to address a flat, Italian battery when it refuses to start Ones Falco
Fixed that for you - Answer is YES! ;o)
'00 Falco fire red w/35.000km. New to me in '12.
