zoidberg
#121
by zoidberg » Mon Jun 24, 2013 9:44 am
Whilst the bike is still in bits awaiting ht leads is there anyway of removing the front sprocket without splitting the chain?
#122
by D-Rider » Mon Jun 24, 2013 10:07 am
Yes - undo the bolt and pull it off
zoidberg
#123
by zoidberg » Mon Jun 24, 2013 10:25 am
Tried that, the chain didn't like the idea
Falco668
#124
by Falco668 » Mon Jun 24, 2013 10:36 am
Get the rear wheel as far forward on the adjusters as poss, or even remove the rear wheel, sprocket will be more than happy to come off, prob solved!
Old age pensioners, hah, should be shot at birth!!!.
05 Bronze 'n Black. Nice!
zoidberg
#125
by zoidberg » Mon Jun 24, 2013 10:37 am
The wheel was out when I tried.
I'll have another go.
zoidberg
#126
by zoidberg » Tue Jun 25, 2013 7:24 am
No matter how much I bleed the clutch it won't fully disengage.
Is this also a symptom of a leaking slave cylinder?
#127
by blinkey501 » Tue Jun 25, 2013 7:48 am
zoidberg wrote:No matter how much I bleed the clutch it won't fully disengage.
The slave cylinder will weep fluid pass the seals. Remove it from the bike and look.
Firestarter
- Twisted Firestarter
#128
by Firestarter » Tue Jun 25, 2013 8:32 am
Also, has it got aftermarket levers. I remember someone (D-Rider probably...) saying something about the pin in the lever not being set right, an therefore doesn't travel far enough to disengage the clutch. But, if it was working before and you haven't changed the levers, then it's probably not this
PH1969
#129
by PH1969 » Tue Jun 25, 2013 10:27 am
Looks like you bought a puppy
2013 KTM 990 SMT
2001 Aprilia Falco
2002 Buell X1 Lightning
1967 T120R
#130
by D-Rider » Tue Jun 25, 2013 11:24 am
Is the level going down in the reservoir?
If not you've probably still got air in there. If it's going down, you've probably got a leaking seal.
Can't beat having a bleed nipple at the master cylinder end to get the air out.
zoidberg
#131
by zoidberg » Tue Jun 25, 2013 11:55 am
Standard levers. It just drags when I roll tge wheel by hand. It moves but its not fully disengaging.
zoidberg
#132
by zoidberg » Tue Jun 25, 2013 11:58 am
PH1969 wrote:Looks like you bought a puppy
Not at all. Has a few problems to sort, it's to be expected of a bike of its age.
zoidberg
#133
by zoidberg » Tue Jun 25, 2013 12:00 pm
D-Rider wrote:zoidberg wrote:No matter how much I bleed the clutch it won't fully disengage.
Most likely wants bleeding again. It weeps a little and I'll probably get a new slave.
It's tge problem with shite weather. Too much time tinkering not enough riding.
PH1969
#134
by PH1969 » Thu Jun 27, 2013 6:28 am
zoidberg wrote:PH1969 wrote:Looks like you bought a puppy
You're right, there won't be much wrong with it. These bikes are pretty bulletproof. Hope you enjoy it.
2013 KTM 990 SMT
2001 Aprilia Falco
1967 T120R
zoidberg
#135
by zoidberg » Thu Jun 27, 2013 7:41 am
I'm sure I will thanks. Just waiting for some decent weather.
After a search on here and AF1 it appears that the clutch drag issue is really common when cold?
HT leads are here today so I can get those on and the airbox etc back on
