General Aprilia banter
nteck uk
- Despatch Rider
#1
Post
by nteck uk » Sun Mar 11, 2012 7:42 pm
Is there a fix for a switch that comes on if you shorten the span adjuster.
Can have it long reach light ok ,or comfy light on until you tap it or change gear.
RSV-R
was sv curvey
Firestarter
- Twisted Firestarter
#2
Post
by Firestarter » Sun Mar 11, 2012 8:14 pm
Eh? The first sentence kinda made sense (at least in terms of English), but after that?
Not sure why changing anything on the span adjuster would affect the brake light
nteck uk
- Despatch Rider
#3
Post
by nteck uk » Sun Mar 11, 2012 10:29 pm
When the span is close to the bar slightly more of.it fits into the mounting slot ,more friction? though ptfe spray has no effect.
Gear change might be the jolt enough to move it out?
Looked on the parts dig, no return spring shown.
RSV-R
was sv curvey
#4
Post
by Aladinsaneuk » Sun Mar 11, 2012 11:17 pm
i would be tempted to take the switch out and have a close look... budget for a new one.....
#5
Post
by D-Rider » Mon Mar 12, 2012 12:57 am
If it's causing problems you could always fit a pressure operated one - I've had to do that for my radial master cylinder as it doesn't have provision for the normal switch.
nteck uk
- Despatch Rider
#6
Post
by nteck uk » Mon Mar 12, 2012 10:11 am
Can you post a link were you got your pressure switch ,please .
RSV-R
was sv curvey
#7
Post
by D-Rider » Mon Mar 12, 2012 10:47 am
nteck uk wrote:Can you post a link were you got your pressure switch ,please .
Nope - sorry. I bought it with the master cylinder second hand.
However ..... I believe you can buy them from here:
http://www.moto-racing.co.uk/cat--Bremb ... pares.html
nteck uk
- Despatch Rider
#8
Post
by nteck uk » Mon Mar 12, 2012 11:57 am
Found the bolt and switch ,thanks .
RSV-R
was sv curvey
