Kill switch has packed in
Blackranger68
#1 Post by Blackranger68 » Sat Sep 17, 2011 1:17 am
Can anyone tell me if the newer Mille and RSV start and kill swith gear is a straight forward swap over?
anzacinexile
#2 Post by anzacinexile » Sat Sep 17, 2011 9:53 am
Do what I did when mine caused a momentary cut whilst I was leaning over and I didn't want that to happen again and short the wires bypassing the switch.
Its meant to be a MoT failure if it doesn't work but in 6 years, its never been checked
#3 Post by Falcopops » Sun Sep 18, 2011 12:24 am
Pop the switch open and give it a good clean, prolly only got some corrosion on the terminals.
D-Rider did a write up somewhere.
#4 Post by D-Rider » Sun Sep 18, 2011 7:54 am
Falcopops wrote:Pop the switch open and give it a good clean, prolly only got some corrosion on the terminals.
That was the horn switch, Dale.
I think the starter button is probably the same but the kill switch is probably different.
#5 Post by Aladinsaneuk » Sun Sep 18, 2011 9:30 am
I may have spare switch....
Repeat may
The Mad Hatter
#6 Post by The Mad Hatter » Sun Sep 18, 2011 10:35 am
I definately have a spear.
Falconihlist
#7 Post by Falconihlist » Sun Sep 18, 2011 10:37 am
The Mad Hatter wrote:I definately have a spear.
Is that for a long distance start? :smt002
Black is fastest!
The Mad Hatter
#8 Post by The Mad Hatter » Sun Sep 18, 2011 10:55 am
Damn trying to type and feed the kids at the same time.
#9 Post by randomsquid » Sun Sep 18, 2011 12:51 pm
You feed the kids with a spear?
The Mad Hatter
#10 Post by The Mad Hatter » Sun Sep 18, 2011 1:39 pm
Its like feeding time at the zoo in here at times.
#11 Post by D-Rider » Sun Sep 18, 2011 6:55 pm
randomsquid wrote:You feed the kids with a spear?
Asparagus and Broccoli all the way in the randomsquid household, it would seem ...........
#12 Post by randomsquid » Sun Sep 18, 2011 10:35 pm
No way. That sounds like fruit and/or vegetables.
Blackranger68
#13 Post by Blackranger68 » Sun Sep 18, 2011 10:47 pm
Took the switch apart, seems like someone has cut the wires on the kill part of the switch, maybe as a result of the side stand switch not working and had been by passed.
I have sorted the side stand switch out with a honda fireblade side stand switch. If the kill part of the switch has been butchered, I will defo need a replacement. Anyone got one that they would be prepared to let go for a small fee?
I see one on ebay but it looks a bit faded.
The Mad Hatter
#14 Post by The Mad Hatter » Mon Sep 19, 2011 9:01 am
Mine definately survived the crash so is available.
