Difficulty finding Neutral!!!!!!!!!!!!!!!!!!!!
Blackranger68
RTFM?
#16 Post by Blackranger68 » Tue Aug 23, 2011 8:43 pm
Thanks guys for your wisdom, I give it a crack and see if it helps.
I am a bit confused though with the technical abreviation of RTFM? Cant think of any mechanical knowledge that would fit those letters.
There is also the issue of where do I get hold of the needle jet for the slave cylinder should all else fail?
thanks in advance
Oh I have managed to get a shock and linkage from Tash RSV that he is breaking, hopefully that will sort the wooly suspension
Can anyone tell me is this an easy replacement for the blue shock and linkage?
Re: RTFM?
#17 Post by D-Rider » Tue Aug 23, 2011 9:07 pm
Blackranger68 wrote: I am a bit confused though with the technical abreviation of RTFM? Cant think of any mechanical knowledge that would fit those letters.
RTFM = Read The F-ing Manual
Blackranger68 wrote: There is also the issue of where do I get hold of the needle jet for the slave cylinder should all else fail?
:smt017 errr .... not sure what you mean ........
Do you mean the clutch oil jet ? (nothing to do with the slave)
If so, any Aprilia dealer, Ultimate Parts or Griff at Aprilia Performance
Bolt on job. Easy enough to do but you will need to support the bike from somewhere other than the swingarm - eg from the swingarm pivot using an Abba or Ulti pro stand - or improvise.
If you don't have such a stand you may find a forum member near enough who has.
Where are you based?
Blackranger68
Neutral
#18 Post by Blackranger68 » Thu Aug 25, 2011 9:59 pm
Yes thats what i mean clutch oil jet.
Where does it fit, the master cylinder or the slave cylinder?
I live in Norn Iron, a little place called Ballymena.
Re: Neutral
#19 Post by D-Rider » Thu Aug 25, 2011 10:42 pm
Blackranger68 wrote:Yes thats what i mean clutch oil jet.
Ah - not so easy for most of us to pop round and lend a hand and equipment then!
The clutch oil jet squirts oil on the clutch itself - so it's not anything to do with the hydraulic actuation system (master / slave cylinders etc) but fits within the crank case (behind a screw not far from the slave cylinder)
This is the jet (along with some tools)
Here's where it goes (behind that screw):
#20 Post by Samray » Thu Aug 25, 2011 10:47 pm
One of Aladin's fav links .... but I should start at the last page. :smt002
http://www.apriliaforum.com/forums/show ... p?t=116184
k1w1boy
#21 Post by k1w1boy » Fri Aug 26, 2011 12:24 am
meh - my high-milage old nail had many problems - largely due to low-level neglect :smt016 - but neutral was always reliable from 1st.
Re: Neutral
#22 Post by mangocrazy » Fri Aug 26, 2011 6:05 pm
Blackranger68 wrote:I live in Norn Iron, a little place called Ballymena.
Home of Yer Maun himself, if I'm not mistaken. A great man and sorely missed.
Re: Neutral
#23 Post by D-Rider » Fri Aug 26, 2011 6:31 pm
I thought Joey was from Ballymoney
#24 Post by flatlander » Fri Aug 26, 2011 6:52 pm
is this something that benefits all falcos or did the later ones already have this changed... can't remember where I read that but i did read it somewhere :smt002 :smt017
anzacinexile
#25 Post by anzacinexile » Fri Aug 26, 2011 7:31 pm
flatlander wrote:is this something that benefits all falcos or did the later ones already have this changed... can't remember where I read that but i did read it somewhere :smt002 :smt017
I believe that all the Falcos were the same but they changed the jet size on later Millies....................
.....but I could be wrong
Re: Neutral
#26 Post by mangocrazy » Fri Aug 26, 2011 8:15 pm
You're absolutely right. I am mistaken. :smt053
#27 Post by D-Rider » Fri Aug 26, 2011 9:46 pm
From memory the later Falcos got the first change in jet size (was it 75 to 60 ?) but certainly only the later style RSVR/RSVR Factory + equivalent Tuonos got the 40.
Again .... I could have remembered incorrectly ..........
#28 Post by flatlander » Fri Aug 26, 2011 9:54 pm
Bugger I have an 04 and a clutch jet new so I'll go ahead and do it anyway:)
Blackranger68
Re: Neutral
#29 Post by Blackranger68 » Fri Aug 26, 2011 10:06 pm
[quote="D-Rider"][quote="mangocrazy"][quote="Blackranger68"]I live in Norn Iron, a little place called Ballymena.[/quote]
Home of Yer Maun himself, if I'm not mistaken. A great man and sorely missed.[/quote]
I thought Joey was from Ballymoney[/quote]
Yes he was from Ballymoney thats just 15miles from where I live.
Blackranger68
#30 Post by Blackranger68 » Fri Aug 26, 2011 10:08 pm
[quote="flatlander"]Bugger I have an 04 and a clutch jet new so I'll go ahead and do it anyway:)[/quote]
Did Griff get you the clutch jet?
