However I still have no idea what the original problem was / could have been, as it turned out it wasn't the sprag clutch that was at fault.
My mechanic (what a top bloke!) collected the bike on Monday and rang me yesterday to ask if I had removed the starter motor!!!!...It turns out when I checked the brushes on the motor I then managed to refit the cover backwards and the motor was running in reverse
He repaired the starter motor (well turned the cover around) and the bike fired up straight away! I've now started her up about a dozen times and all appears well. But the question remains "what the bl**dy hell was wrong the first time". When we looked at it on Saturday (Tweaker & I) it was still just clicking until we shorted out the solenoid (The new one) when we got the "whirring"
I can't believe anything was jammed as I rocked the bike in gear and even managed to get the enging to turn over, trying to bump start it, so surely that would have free'd anything stuck in the idler gears or starter motor???
It may well remain a mystery
F9
