2003 mille shock linkage.
maz
Main bike: Tuono V2
#1 Post by maz » Sun Jun 12, 2011 7:17 pm
Hi, i have a gold yellow spring shock off a 2003 mille to fit to my Falco, only I need the corresponding link plates and dogbone, If anybody has a set lurking
in with their spares and would like to sell to a good home I would be very grateful.
Or if anybody has suggestions where I can get said links for a reasonable price that would be much appreciated.
Thanks.
#2 Post by Aladinsaneuk » Mon Jun 13, 2011 6:44 am
I would be tempted to call the known aprilia breakers
I know you have the link to af1 guide on assorted shocks and I think there is a set of part numbers in the thread.... Or at least a good visual guide to the differences
#3 Post by D-Rider » Mon Jun 13, 2011 9:13 am
Aladinsaneuk wrote:I would be tempted to call the known aprilia breakers
You can get all the part numbers from the Ultimate Parts website :smt002
Moose
#4 Post by Moose » Wed Jun 15, 2011 4:45 am
:smt006
I have some spare linkages :smt001
could someone post up a picture of the ones required for this shock (with measurement for dogbone, please), I will check them against what I have.
I am heading up to Helmsley now for the farmyard party :smt003 Yippee, but I am working :smt012 BOO HOO, so won't be back online till Tuesday next week.
Moose
#5 Post by Moose » Wed Jun 22, 2011 9:47 pm
bump!
Does anyone know the measurements????
#6 Post by mangocrazy » Thu Jun 23, 2011 8:15 pm
Hi Moose, this post on the AF1 forum should tell you all you need to know:
http://www.apriliaforum.com/forums/show ... stcount=17
Moose
#7 Post by Moose » Wed Jun 29, 2011 7:00 pm
Hi after checking the link & my linkage bits, here goes,
Please note the measurements are by eye with a tape measure so are only a guide
I have two dogbones one is from the Falco (I think) & is 107mm hole centres and 35mm wide, pins are 40mm, the other is from a tuono and is 120mm centres but only 33mm wide, pins are 35mm.
plates, I have three sets
Set No'1 (Falco) A = 76, B= 85 & D = 62mm centres
Set no'2 Tuono A= 71, B= 83 & D = 55mm centres
Set No'3 ?? A= 84, B = 80 & D = 87mm centres, this set is a light weight ally, which Aladinsane thinks may have been a recall.
Hope this is of use to you.
Moose
#8 Post by D-Rider » Wed Jun 29, 2011 7:59 pm
Moose - if you can post pictures, I can confirm whether they were the ones where there were some failures - however, to the best of my knowledge, Aprilia never issued a recall (he's probably thinking of the RSVR swingarm recall)
Moose
#9 Post by Moose » Fri Jul 01, 2011 8:23 pm
These are the light weight triangles
These are set number1
And this shows the difference in the Tuono (clean) and the falco (dirty) dogbones
Moose
#10 Post by D-Rider » Fri Jul 01, 2011 9:02 pm
Moose wrote:These are the light weight triangles
Falco and very early Mille
Moose wrote: These are set number1
pre 04 Mille / pre 05 Tuono
Moose wrote: And this shows the difference in the Tuono (clean) and the falco (dirty) dogbones
Moose
Post 03 Mille / Post 04 Tuono
These are the ones here there were some failures - I did post some pics up on here of the failures
maz
Main bike: Tuono V2
links
#11 Post by maz » Tue Jul 05, 2011 4:19 pm
Hi Moose, sorry about the delay, thanks for the measurements, I will now try and find out if these are the correct ones to match the sachs yellow spring shock?.
