renegade mille mid section mod - further thoughts
cornish mafia
#106 Post by cornish mafia » Sun May 22, 2011 5:39 pm
I'm sure it's perfect and just what i want but the link doesn't open it ...............maybe a space in between Mean and HTTP i don't know ...
Thanks anyway though ..
#107 Post by Samray » Sun May 22, 2011 5:42 pm
:smt017 What browser are you using Cornish?
cornish mafia
#108 Post by cornish mafia » Sun May 22, 2011 9:13 pm
First time a link hasn't open for me on here , all it says is "topic does not exsist" when it goes there and it's just the link as well so was wrong about the gap thing ..........bloody computers !! :smt017
https://www.ridersite.com/viewtopic.php?t=8132 ................ copy and pasted here and still doing the same thing.
I'm on windows 7 home p using internet explorer and like said never had a prob before ....
#109 Post by Kwackerz » Sun May 22, 2011 10:06 pm
Aprilia tech forum on here, second down after the stickies.. 'grubby bike...'
fks what the link problem is! hopefully we'll find a solution or reason soon tho'
#110 Post by MartDude » Sun May 22, 2011 10:27 pm
cornish mafia wrote:First time a link hasn't open for me on here , all it says is "topic does not exsist" when it goes there and it's just the link as well so was wrong about the gap thing ..........bloody computers !! :smt017
Had that myself earlier tonight
https://www.ridersite.com/viewtopic.ph ... ight=buell
#111 Post by Kwackerz » Mon May 23, 2011 8:22 pm
:smt017 hmm works fine on my phone with opera.. Might be a problem with a windows update. When I get back from this field im in for the next week and a half ill do some investigating.. Must say ive had 1 occurrence but other than that its always played fine..
#112 Post by Aladinsaneuk » Mon May 23, 2011 10:06 pm
there has been something strange going on with a few uk web sites recently - and not just associated with windoze....
cornish mafia
#113 Post by cornish mafia » Thu May 26, 2011 1:42 pm
Ok so just need to know about "THE CUT " needing to be done to my newly sprayed bellpan after fitting the new oil tank .........How much do i need to take out roughly before i start going mad with the chainsaw !!! :smt013 Got to go and clean up my nice oil slick in the garage now but will wait till i hear form you guys who have done it first before trying to fit bellypan .........by the way .............PHOTOS I'M GOOD WITH PHOTOS !!! :smt017
Oh and only lost the skin on three fingers as well , lost about two pints of blood but will make that up later in the pub !!!
#114 Post by Aladinsaneuk » Thu May 26, 2011 1:50 pm
http://www.flickr.com/photos/43649187@N ... 594046335/
not much of a cut as you can see
i suggest that offering the belly pan up is the easiest way to see it - i cut an ellipse out of around 4cm long and 0.75 cm wide - but offer it up and see
cornish mafia
#115 Post by cornish mafia » Thu May 26, 2011 2:23 pm
Aladin that is spot on mate thank you very much :smt023 , now my hand may not be shaking so much when i go for it ......
Am keeping that page up and taking laptop to garage to now work step by step ......if it goes wrong now it's your fault !!! :smt005
Still waiting on exhaust but thought i might as well get it done as it's raining outside and blowing a gale , hope it turns up soon as i've just had the dreaded call to go back to work for the 2nd ............Less then two weeks at home , BOLLOCKS ! :smt013
#116 Post by Aladinsaneuk » Thu May 26, 2011 5:05 pm
No worries mate
And I will pm you some time - I quite fancy your holiday chalet - and not for mates rates either!
cornish mafia
#117 Post by cornish mafia » Thu May 26, 2011 6:59 pm
It's alive I tell you it's alive !!! :smt077 All back together again albeit a "tighter” fit then normal with the fairing and that's after hacking in with a dremel ( must confess top mate turned up just in time as I was about to hack in so quite happily stepped aside and let him crack on being the skilled man he is..........well what are mates for !!)
Everything is looking good re-rooted cooler pipe where it should be and all fairing bolts back in BUT ( there's always a BUT ) I notice the oil tank touches the fairing just back from the cut which would mean taking loads out so I’m assuming it's an OK to leave as is ???
Will wait till i get full nod of agreement from the gods before i start smiling and by all means get in touch if you fancy staying just check the calander on the web site for free dates ... :smt003
#118 Post by Aladinsaneuk » Thu May 26, 2011 7:40 pm
Please post a picture of where it is touching
cornish mafia
#119 Post by cornish mafia » Fri May 27, 2011 9:06 am
OK here goes and taken from phone camera as well so not the best :
First one is looking back through "the cut " towards the rear :
Second is looking down with " the cut " up front : -
Doesn't look like i need to make "the cut " any bigger as it's not touching at he front now , was thinking maybe a bit of bending on the tank lugs to try and get it to sit in closer to the bike ?? It's touching pretty much an inch & half either side of the green white join .......
#120 Post by Aladinsaneuk » Fri May 27, 2011 9:09 am
I would be tempted to try and space out the top of the mounts using a couple of washers - better than trying to bend lugs i think
