http://www.ultimateparts.net/aprilia/c. ... e-&i=18125
I've removed the swingarm pin/O rings/gasket rings and spindle nuts, what's left are the needle bearings/O rings/Gasket ring...
1) Do these come out, if so how?
2) Or should i leave them in and ask the powder coater to mask them off?
...same questions for above section where the shock goes (sorry don't know technical term!)
1) Remove?
2) Or mask off?
The chainguard bolts are stuck solid...any suggestions how to loosen and remove...or should i mask off and hope for the best when powder coating?
Alan key socket is threaded so i can't remove one of the paddock stand bobbins...is there a way of removing and still being able to use the hole for another bobbin, or shall i just leave it on and powder coat over it??
Filling- Will be heading down to Halfords to get some body filler and wet/dry paper as there's a few deep scratches here and there...will this be okay?? Let me know what else i need??
Will be asking the powder coater for his input but as ever your advise is 'golden'
Sorry for the dumb questions but it's a steep learning curve for a newbie
