On my previous Falco I swapped them for Tuono indicators but when I got my Tuono I then swapped to these Shiver indicators (below)
So whilst waiting for the weather to improve allowing me to get some work done on the Falco I saw some Shiver indicators for sale on eBay from the Rocket centre in Blackburn (Aprilia main dealer)
I asked them what the best deal they could do on a set of four would be (these are the same indicators fitted to the RSV4) and £26 was the reply
I picked them up today and they are brand new (of course) still in the bubble wrap and inc the bulbs. They also have exactly the same mounting as the Falco ones and you can use the same fixings to boot.
I reckon £26 is an absolute bargain (IMHO) but it is worth pointing out you need to use the Falco wiring as the block connectors are different (smaller) on the new indicators. Its a very easy job to do though, you just remove the indicator lens and reflectors from both the old & new indicators. Then remove the 2 electrical connectors from the back of each reflector and remove the wires from both indicators. Swap them over and voila!. Its a 5 min job per indicator max
I thought I'd mention it to my fellow ARS members as others may also fancy a cheap upgrade without having to butcher the wiring or add resistors to use other indicators etc... The parts man there said they sell literally hundreds of these indicators across the country
F9
