#16
Post
by mangocrazy » Thu Sep 30, 2010 8:45 am
BenWah wrote:It was interesting to see how much strain there was in the rear part of the subframe. During the welding process it must have distorted because once one of the frame rails was cut, the rest of the rear frame released slightly.
BW
Not down to carrying porky passengers, then?
BenWah
- Track Day Addict
#17
Post
by BenWah » Thu Sep 30, 2010 9:32 am
Not on my watch...
- Double World Champion
#18
Post
by Samray » Thu Sep 30, 2010 12:08 pm
BenWah
- Track Day Addict
#19
Post
by BenWah » Thu Sep 30, 2010 12:17 pm
A little. But mine will be lighter - and far cheaper!
BenWah
- Track Day Addict
#20
Post
by BenWah » Thu Sep 30, 2010 7:39 pm
More weighing.
Took receipt of some lovely Renthal sprockets and a Tsubaki chain from B&C Express today. These are the results:
42T standard steel sprocket - 1.12kg
42T 520 Renthal Ultralite - 0.27kg
17T steel front sprocket (no idea why either...) - 0.31kg
15T 520 Renthal Ultralite - 0.19kg
Standard chain - 2.16kg
Tsubaki 520 chain - 1.94kg
Total weight saving from swapping standard chain and sprockets is a whopping 1.19kg or 2.62lbs.
B
#21
Post
by Samray » Thu Sep 30, 2010 8:12 pm
Wow. Surprised at that.
#22
Post
by D-Rider » Thu Sep 30, 2010 8:17 pm
Looks as though most of this comes from the sprockets and relatively little from the 520 chain.
I guess hard anodised ally rear sprockets are the way to go to save mass - unsprung and rotational at that.
.... just as well I've got one of those for my new wheels then
Noeli0
- Despatch Rider
#23
Post
by Noeli0 » Thu Sep 30, 2010 8:52 pm
hey Ben, can you take off the alternator and run it as a total loss system? is this allowed in the regs?
also the starter is a bit of weight is that allowed to go?
- GP Racer
#24
Post
by Falcopops » Thu Sep 30, 2010 10:15 pm
Noeli0 wrote:hey Ben, can you take off the alternator and run it as a total loss system? is this allowed in the regs?
took the words right out of my mouth, both weighty bits of kit!
BenWah
- Track Day Addict
#25
Post
by BenWah » Fri Oct 01, 2010 5:58 am
Both possible, but for ease of use both are staying. There's a bloke in the paddock with a lovely flat track style Triumph that's a pain in the bum to start - he always needs assistance. Try bump starting a falco! Especially one that has a lot less mass...
However - in other news, the battery that came out weighs 4kg. The one going in weighs 0.73kg!
#26
Post
by MartDude » Fri Oct 01, 2010 10:16 pm
Ben, could you please post up the info re that battery - I know you told us in Norfolk, but the red wine seems to have fouled my memory circuits
BenWah
- Track Day Addict
#27
Post
by BenWah » Wed Feb 02, 2011 2:19 pm
It's been a while since I posted anything about the Falclimber, so here's something to bring progress up to date.
The bike came with a horrendously bad knock from the bottom end and as such, the whole bike came for £500 from eBay. It turns out the flywheel was loose and had been knocking backward and forward against the woodruff key. This led to the keyway being widened a significant amount. I successfully repaired the woodruff keyway with chemical metal, lapped the taper and flywheel back together and fitted a new sprag while I was in there (the one in it worked but was very worn/scored).
It now runs very sweetly indeed. This is a pic of it last weekend after getting it running and fitting the single seat unit from Italy. The seat is away for painting at the moment and I'm waiting for a mate to come up and build a race wiring loom for it - the wiring that's behind the lights won't fit behind a number board.
#28
Post
by Samray » Wed Feb 02, 2011 2:33 pm
Looking good.
BenWah
- Track Day Addict
#29
Post
by BenWah » Wed Feb 02, 2011 2:38 pm
Thanks Sarusam. I'm starting to get excited about the season now.
It's looking likely that it'll hit the scales at 180kg ready to go. Possibly.
#30
Post
by Aladinsaneuk » Wed Feb 02, 2011 5:32 pm
you going for the oberon or mpl clutch?
