New rider, new owner, not new bike.
Right. Just been and looked at my bike.
I've also got a shock of a 2000 RSVR I fitted a while back
It's got 1093 54/140 359 on the spring
And AP 8230 stamped on the top of the shock
When I bought it, I also bought the linkages and dog bone that came with it. Just checked them against my old falco linkages and dog bone. And I can confirm they both are EXACTLY THE SAME
Hope this helps you out!!!
Falconihlist wrote:Just got home and got the shock out of the box. The number on the spring is 1093-54/140 350 so hopefully that is from a sub 2000.5:) would make life easier if it is just a matter of swapping out the shocks. May order some new bearings anyways as it is all coming apart.
Have already found out that the bike is on the responsive side, so I will definitely be taking things very easy, especially with the tunnel visioned drivers about. Wouldn't mind an armoured escort for route clearance.
Does anyone live around the Camberley area?
tommy wrote:Right. Just been and looked at my bike.
Excellent - you both have 140Nm springs which will work with the Falco linkage.
It's those (more common ones) with the 95Nm springs that need the mille linkages.
go_modem_go from AF1 wrote:We should make that a sticky. I've also written up at least 5 or 6 summaries, including spring rate readings and Öhlins shock numbers on that subject.
Linkage means: Triangles as well as dogbone.
Mille or Falco Swingarm doesn't matter.
Mille / Tuono Sachs shocks may need a little grinding to the upper black plastic damping rate adjuster knob / valve.
- Blue Sachs (OEM) = Falco linkage (or Mille 98-2000). Obviously.
- Öhlins AP840 140+Nm spring from Mille R = Falco linkage (or Mille 98-2000)
- Öhlins AP 941 side reservoir, no height adjuster (Öhlins Falco aftermarket) = Falco linkage (or Mille 98-2000)
- White Sachs from Mille = Falco linkage (or Mille 98-2000)
- Öhlins AP8240 with 95Nm spring from Mille R = Mille 01-03 or Tuono pre-06 linkage
- Yellow Sachs from Mille 01-03 or Tuono pre-06 = Mille 01-03 or Tuono pre-06 linkage
Super dooper. Cheers DR, that's what I was thought it was, but was never 100% certain.
Although I do need to go get my shock played with. It's still shooting me out of the seat occasionally on bumpy roads. I put it down to just being a light weight
Mind you, its soooooo much better than that blue thing that was on there
So Falconihlist, get that ohlins on there ASAP!! lol
Yes, the Ohlins is in another (far more advanced) galaxy compared to the Sachs blue spring shock!tommy wrote:Super dooper. Cheers DR, that's what I was thought it was, but was never 100% certain.
However I found that the 140 N/mm (800 lb/in) spring rate was still too firm for my liking. Even with the missus on the back it was too firm. So I took the plunge and ordered a softer spring (700 lb/in - 122.8 N/mm) and that was much better. Solo it was nice and taut, but I wasn't getting kicked out of the seat, two-up it was nice and plush.
I ran this past John at Revs Racing and he told me that this was very close to Ohlins recommendation for the Falco-specific Ohlins shock.
- Falconihlist
Klasse:) That would be a big bonus. I'm looking forward to doing some stripping and reassembling over the next few weeks. Went for another lesson yesterday on a Suzi 500 and it felt like I was strangling a chicken to get up to speed on the back roads compared to the Falco.
Think I am going to have to get a wrist lock before I lose my licence
I can't remember who's bike it was, but I saw a single side exhaust kit, looked awesome, but does anyone know of a company that can do twin underseat setups?
Black is fastest!
only company that may be able to make something for you would, i guess be fuel
the under seat exhausts are not exactly common...
am certain greybeard will be along shortly with correct advice
- Falconihlist
Just had a look on their site, looks like I will have to wait till the 13th to get in touch with them as they are on a holiday at the moment.
Just ordered a set of Renthal sprockets and chain, so it looks like I will be devoting a day to getting the back end sorted.
Once I have an idea for the exhaust, then I can get round to doing the tail tidy. I now have a vague plan as how I want the bike to look, just have to work out how to use the demon photoshop and start doing some renderings!
Black is fastest!
Might have been mine .........Falconihlist wrote: I can't remember who's bike it was, but I saw a single side exhaust kit, looked awesome, but does anyone know of a company that can do twin underseat setups?
https://www.ridersite.com/viewtopic.php?t=7003
that's a Fuel can on there (at the moment) BTW.
The only company that I can think of that did a proper underseat kit was Renegade - but I've never seen one.
- Falconihlist
Expect pain.
If you do it yourself i'd invest in a swearbox, you'll be minted!
If you get a company to make them for you, expect a very light wallet at the end.
You're looking for something like this?
There's an old thread here: http://www.apriliaforum.com/forums/arch ... 29296.html
that with a bit of username searching, you'll probably find out some useful info
- Falconihlist
I do like the high mount look, but I would like to actually get smaller cans and get them right underneath the tail, if I can work around the rear wheel travel. I will have to have a good look and see what the prohibitive parts will be. If not, then it will have to be high mounts, as I won't be carrying anyone pillion anyways.
Black is fastest!
I might be wrong but I thought they were the Rene Hi-mounts not the under seats.Aladinsaneuk wrote:thought will's bird had underseat falco renegades?
and my underseat renegades are mille issue btw :)
they are like hens teeth though.....
I believe they had both on their price-list and were not the same.
Tweaker had some too - but I think they were Hi-mounts (though, again, could be wrong)
i have just been looking through my assorted renegade images - some men look at porn - I look at exhausts.... anyway, I have not got any image of full underseat renegades... they may have been on the price list but were any made or sold?
Take out and relocate rear light and relays etc, and have a custom end can made up to fit the hole under the pillion seat. Kinda ducati 749/999 style. Use current link pipes and have them routed up similar to high mounts. May not be that much of a head ache to do. Seen a falco on youtube with this set up. Think it looks pretty cool, have a look:
http://www.youtube.com/watch?v=jYCsZFguhLI
