Starting issue
Starting issue
Is this a common problem?
When I start my falco it seems to hesitate, 'click' and then start. At the 'click' point it appears to restart the battery and so the computer resets itself. This means I have to reset the clock, change back to mph and reset the rev limiter. This even happens at fuel stops.
1998 Buell S1WL
2001 Aprilia SL1000
2002 Buell X1
2010 Norton 961SE
2001 Aprilia SL1000
2002 Buell X1
2010 Norton 961SE
Yes - usually a sign that your battery is needing to be retired for a new one.
Nevertheless, check all connections are clean and tight first - but my money is on a new battery being the solution.
Worth the money as starting with a weak battery can have an adverse effect on the sprag - besides the hassle of sorting out the resets all the time.
- furygan man
Hey DRider looks like you should pull both our threads together!!
PH100- Having starter issues too!!
Have just had chat with DRider and have just ordered one of the Yuasa batt's people seem to recomend as it was becoming a bit of a lottery starting the thing
My battery was fortunate in having a date on...2005, so time for a change
...I just hope that fixes it...good luck with yours!
- mrapriliafalco
- furygan man
http://images.esellerpro.com/2189/I/111 ... rger-1.jpg
...have one of these but didn't use it on this instance, but i think the batts defuncked anyway
Good tip, however if your battery is completely sh@gged an optimate will not help, as I've found out.mrapriliafalco wrote:I had the same problem, bought an optimate on ebay and now its as good as Gold
By all means buy one, but it might be too late to recover your current battery.
Things I did were:
- wire mod,
- new battery,
- yamaha starter relay
Over a year now, ~13k miles and it hasn't failed to start, or popped a reset.
I had one of them, it showed the battery healthy, and it wouldn't even try to spin the engine.furygan man wrote:http://images.esellerpro.com/2189/I/111 ... rger-1.jpg
Was replaced by an optimate 4 very quickly.
- furygan man
- anzacinexile
Start relay is virtually plug 'n' play
....wiring mod isn't though
A wire mod is soldering extra wires between the battery and the reg/rec. Basically you're improving the connection:
http://www.apriliaforum.com/forums/show ... hp?t=64758
The Yamaha relay is a 100A unit whereas the Aprilia uses a 50A version, I think. You can order it from your Yam dealer, part no:
4KD-81940-00-00
or this one
http://cgi.ebay.co.uk/STARTER-RELAY-APR ... 45f384f7ae
4KD-81940-00-00
or this one
- furygan man
...as i said...haven't a clue, have read this a while ago and still no clearer, lots of words and no pics...not good for someone like me!A wire mod is soldering extra wires between the battery and the reg/rec. Basically you're improving the connection:
...thanks for this but again, wouln't have a clue what to do with it!The Yamaha relay is a 100A unit whereas the Aprilia uses a 50A version, I think. You can order it from your Yam dealer, part no:
4KD-81940-00-00
or this one
- furygan man
- furygan man
