chain wheel clearence?
has anybody came across chain clearance problems? have fitted a set of pirelli diablo rosso corsas, 190 55, and the chain seems to be just kissing the side of the tyre, have had the wheel off, checked spacers, sprocket carrier, everything, made sure wheel was sitting straight, un adjusted chain, re adjusted chain, still very tight, tried to measure the tyre width and it seems to be closer to 196mm or 197mm, rather than 190. could this be the problem?
- FlyingKiwi
pretty certain i have read of others having similar problems - and there was some variance depending on tyre manufacturer
afraid to say you probably need a new rear tyre
what were the other tyres?
and what pressure you running at?
i think it was on af1 was some one else reported this problem - and i think - repeat think they were the same tyre manufacturer
some useful stuff here
http://www.apriliaforum.com/forums/show ... =tire+size - the mathematics of it
Yep that's my understanding too.fastasfcuk wrote:joe's right 180 is the standard tyre, i think mille's run 190's
As has been said, there have been reports of some problems with 190 section tyres .... and as not all 190 section tyres are the same width (basically there's a tolerance) then some will be worse than others.
Before you completely resign yourself to this being an insurmountable problem, it would be worth checking your rear wheel alignment - if the front of it is pointing slightly to the left, this could be the cause of your problems (and don't use the marks on the swingarm to align the wheel - they are seldom right)
Well, there's the string method:
http://www.motorcyclistonline.com/howto ... index.html
The straight edge method:
(usually a straight piece of wood rather than fluorescent tubes!)
http://www.motorcyclenews.com/MCN/Newri ... alignment/
Or you could make yourself something like this:
http://www.realclassic.co.uk/techfiles/ ... nment.html
- Firestarter
- Twisted Firestarter
Or there's laser alignment, something like this:
http://www.demon-tweeks.co.uk/Motorcycl ... 9/0/117034
Not as cheap as the string method mind!
