I have been quite busy working on some other bikes over the winter, but did have a couple of things that I wanted to do
so, in no particular order....
First off,I wanted to sort out a better way of mounting the Mille renegade cans. I do not use a grab rail at all so... this made sense to me
The brackets are just rough cut and the bolts used are just things that came to hand
Now I have the dimensions etc, I will use the brackets as a template for something nicer, and will use some nice domed bolts to make it look better :)
Also note that my indicators have returned to my old smoked blisters... they are bright but i do like the integration now :)
Next up, I have a garmin zumo and wanted to move its mount from above my clocks to above the headstock.
I have already moved my bars over the triple crown and long term readers will remember that I did drill and tap through a set of bolts as a pin.
I wanted to use a RAM ball mount bar to have a degree of movement, but I am too tight to buy a telferizer mount - so... I made my own variant :)
Here you can see where I have mounted a RAM ball onto some threaded rod - and that locks down into the pin hole and makes a nice ball mount
I have used a long RAM bar so I can move the zumo around - to either come down close to the tank, or to sit up high - if I am using my bagster luggage
Next up, I have a small Camera that I have been struggling to mount successfully for some time - No idea wether this will work or not but...
I made a bracket that comes out of the top of the Fuse box and just puts the camera to where i think it will be ok
Hopefully Team Heat will not notice so much... well - they no doubt will but it does look ok there - and means i can operate the camera - ie turn it on/off while sitting on the bike
I have also sorted out the starcom suppression issues - I have changed a few leads around, and routed power leads differently - now sounds very clear and has all the plug in toys working....
Jobs left to do -
A BLOODY GOOD CLEAN!!
buy a shocktube for my rear shock - I cannot use a hugger as they do melt....
oh - most importantly... RIDE IT!
