is your isp giving you what you pay for ?
To find your exchange put your postcode in the search box here
http://www.samknows.com/broadband/mapping/mapping.php
or your phone bumber here
http://usertools.plus.net/exchanges/
Dave
Better to remain silent and be thought a fool, than to open your mouth and remove all doubt.
Thanks for the input.
I had thought about mobile broad band and may go that way, what has stopped me so far is we run at least three PCs from my house and share the ADSL modem and other stuff, off a small ethernet network. As far as I have seen the mobile stuff tends to be USB which would be problematic to share and, not that I've looked pretty hard, I've not seen one that is ethernet. The other thing is I'm getting broad band within a package of other services such as free international calls etc.
My PC is pretty new dual boot to either XP Pro Sp3 or Vista Ultimate and reasonably specified. I have a newish laptop with Vista as well as two older laptops I've retired to the kids. None of us can get a decent speed of connection.
For many years we could not get broad band at all and I think it was only when a supplier miscalculated that they said they could provide it. I know we are some 4 to 5 miles from the nearest exchange.
So it would be worth going to another type of phone package if I can't get a significantly better modem and if I can get or set up, shareable mobile broad band.
My memory is a little foggy as to what exactly was being tweaked but we had quite a session with the broad band supplier with them altering I think frequencies, at their end and me reinitialising the modem at mine to see if the modem would sync up sufficiently to establish a dialog. This was all to get communication at any level rather than for performance.......
I knew a guy who lived about 10 miles from Penwortham nr Preston, farming country, no neighbours for miles.
He needed broadband for his business, neither BT nor Telewest Cable would help, (BT wanted £30000+) so he had a microwave system setup in relays to the town, only cost in the region of £10000.
Went bust 6 months later.
Dave
- Falco9
Whilst I wait in vain for any sign of action from Tiscali....One month after complaining, loads of telephone calls and e-mails from them but no action whatsoever
I decided today to disconnect my Belkin router and go directly to my desktop from the modem. The result was startling
A fourfold increase in speed over my current connection speed. Nowhere near what Tiscali claim to be delivering to me of course and I'm staying with my decision to move to cable but maybe I just have a dodgy router?. This is still so slowwwwwwwwww but after 2 weeks of 0.25 speeds this feels like doing 150mph in comparison
F9
F9
- Firestarter
- Twisted Firestarter
- Falco9
Hi M8, It is a wired router, I took the ethernet cable that ran into the router and stuck it straight into the PC and voila! I do normally have another ethernet cable that runs back from the router straight to the PC so my desktop is not actually wirelessFirestarter wrote:Wireless router F9? What about connecting via cable into the router (if there is a network port on it?) and re-running the test?
Sorry I'm not very techy on these subjects, so aplogies if I've missed the point
F9
- Firestarter
No mate, you've hit it dead-on. Connected via a wire to the router = not wireless. I'd have a look at your network card configuration and your router.Falco9 wrote:Hi M8, It is a wired router, I took the ethernet cable that ran into the router and stuck it straight into the PC and voila! I do normally have another ethernet cable that runs back from the router straight to the PC so my desktop is not actually wirelessFirestarter wrote:Wireless router F9? What about connecting via cable into the router (if there is a network port on it?) and re-running the test?
F9
One thing I did find (although I didn't run a speed test on it) - when I put a Belkin router on (instead of the "modem"), my connectivity was rubbish. Took an age to open webpages, if it did at all. I was (eventually) directed to a tool by Tiscali customer non-services called Dr.Tcp. There's something called a maximum transmission unit, or MTU, which seemed to be the problem - the default is 1453, set mine to 1400 using this tool and voila! Sorted. The tool only works on XP though - no Vista. Might be worth a look
