Following a suggestion from Ian at Max Moto, I've just bought these
http://www.maxmoto.co.uk/images/Stelvio_hand_guards.jpg
They will fit with no modification to the guards themselves.
However, the bar-ends supplied are about 20 mm too short (with R & G bar end protectors fitted); I'm going to have to fashion some extensions - I was thinking of either casting some in resin, using the supplied bar-end (suitably cut down) as a pattern, or machining some from dense nylon or polypropylene.
UK Guzzi dealers are selling these for about £50 - £55.
I was also thinking of adding some LED strips.
I'll let you know how I get on.
Stelvio handguards for Futura
I looked. They don't/won't.sidestand wrote:I reckon the BMW R1150 GS ones would fit better with less work - just drill out & tap the bar end weights
Must buy a Fut Fut to try me handguards out on
Stop interfering and leave me alone
Thanks anyway, Sidestand
