Zumo Mounting
#16 Post by Fausto » Thu Jun 04, 2009 5:50 pm
's OK then.... :smt020
Syltiz
Chaos Merchant
#17 Post by Syltiz » Thu Jun 04, 2009 9:26 pm
dyzio wrote:Ok, the mounting is made from two "L" brackets and a "T" bracket from B&Q.
One of the brackets was flattened and fits on top of the subframe. I've drilled 2 holes in it and bolted the "T" bracket to it. The second L bracket is attatched to the T one and holds the garmin mounting (M4-or3 bolt + some rubber grommets)
Doesn't look very nice, but hey, it's covered by plastic and does its job perfectly.
Thanks Dyzio. I think that a really good setup
FlyingKiwi
#18 Post by FlyingKiwi » Fri Jun 05, 2009 7:18 pm
wavey wrote:flyingkiwi - I assume you have good access to the ignition switch.Dave
No problem with access. The Zumo sits above and to the left of ignition
FK
#19 Post by DavShill » Sat Jun 06, 2009 11:57 am
I haven't got a sat nav but am thinking of buying one. don't want to spend circa £400 on a bike specific one cos I want to use it the car too.
Daft question probably...... but how do you replace the cigar lighter plug and wire it into the bike? or does it just run off it's own battery?
#20 Post by Aladinsaneuk » Sat Jun 06, 2009 12:08 pm
the proper bike ones wire in correctly to your battery
also, look for a zumo 550 - they have just been replaced with a new model and they come with the correct bits to use in the car....
#21 Post by D-Rider » Sat Jun 06, 2009 12:37 pm
DavShill wrote:I haven't got a sat nav but am thinking of buying one. don't want to spend circa £400 on a bike specific one cos I want to use it the car too.
I've a Nuvi 360 - a nice small car one - I just knocked up a power supply for it which I wired into the bike's wiring - it (and the power feed I made for the heated grips that can't get left on) are contained within the mount I made for the Nuvi.
I've got long-term loan of a Zumo 550 and will be removing the mount for the Nuvi as the Zumo can do a lot more useful things
Dusty
#22 Post by Dusty » Sat Jun 06, 2009 12:54 pm
I mounted a 12V socket on the dash so that I can charge my phone or iPod as well as run the satnav.
#23 Post by Fausto » Sat Jun 06, 2009 5:11 pm
Dusty wrote:I mounted a 12V socket on the dash so that I can charge my phone or iPod as well as run the satnav.
I seriously wonder how some of you can spare the time to look at the road ahead :smt003
#24 Post by Aladinsaneuk » Sat Jun 06, 2009 8:03 pm
rofl
well - lets just say my zumo give me nice warnings about speed cameras... and means i can concentrate on the road ahead!
Dusty
#25 Post by Dusty » Sat Jun 06, 2009 9:21 pm
...and strange as it may seem, iPods and phones can charge away nicely without even casting a glance in their direction. But it's dead handy to be able to use them when you're in the tent ! :smt001
Moose
#26 Post by Moose » Sat Jul 04, 2009 1:17 pm
Hi Everyone
I bought myself the Zumo 660 (It was cheaper than any 550, that I could find!) Having seen Dyzio's rig, it got me thinking :smt017 :smt017 .
As I was fitting the ram mount and the sat nav I decided to got to my local blacksmiths they cut the plate for me (in stainless steel) and charged me a whooping £3 :smt003
(after looking at the brackets Dyzio used it would have cost at least £12 from Focus) Bargain!!
:smt038
Riders view of the plate
Standard Screen riders view
Double Bubble riders view
Without Sat nav fitted
:smt041 :smt041
Moose
FlyingKiwi
#27 Post by FlyingKiwi » Sat Jul 04, 2009 1:42 pm
Good job. If you have any problems with your zumo have a look here www.zumoforums.com
Lots of good info about all the zumo models.
Moose
#28 Post by Moose » Sun Jul 05, 2009 9:33 am
Thanks for the link I have book marked it (not that I expect it to go wrong, just yet)
:smt023
I went out for a short ride after fitting it, and I have to say the position is perfect, (in my humble opinion :smt045 double bubble screen) it is just out of eyeline while concentrating on the road ahead and only a slight look down brings it in to full view.
I hardly looked at my clocks while out, the only time I felt i needed to was after I told the Zumo to take me home :smt052 , the speed was not displayed :smt009 on the screen, however as the clocks are not obstructed it was only a minor thing, I wouldn't be surprised if you can't change the display but as it didn't come with a full destruction manual I will have to trawl the forum above.
Doh! I just found out how to change it, very simple (like me) :smt075
Moose
#29 Post by Moose » Fri Aug 28, 2009 11:43 am
Just an update on the mounting, I changed back to the standard screen and the picture of the riders view is not quite right.
When I started the bike the dreaded default re-set to KMH :smt012 , trip back to zero, went for a ride and the sat nav blocks the view of the fuel light (arse) so you guessed it ? Ran out of fuel :smt100 two miles from home, my good lady :smt061 had to come and rescue me :smt058 .
:smt009 Moose
FlyingKiwi
#30 Post by FlyingKiwi » Fri Aug 28, 2009 6:57 pm
You shoulda used to fuel warning on the Zumo :smt021
Hmmm, couldn't find the stick wacking smiley so used a hammer instead :smt003
