ok all
I will shortly be changing my disks, and while I am at it, I thgt I would change to braided brake hoses - any suggestions on who to go with company wise?
I assume that I should buy a mille set as I have switched to a mille swing arm :)
Brake hoses?
Pete, I bought a set of braided hoses from ebay (pre-used). Price was good so I was prepared that the one for the back brake when I change the swinger may be the only one that fits.
Glad I was prepared as the others aren't long enough!
Think you really want Falco ones for front brakes and clutch and mille for rear brake (or I could try to flog you the front brake and clutch ones that are no use to me!).
Hope this helps!
Hope this helps!
- Despatch Rider
