What needs to be stripped off to replace the steering head bearings on a 2001 Falco, as mine are getting a bit worse and will need replacement soon.
I am assuming that mine are the original non tapered units, so it won't be just a case of tightening them up a bit, having removed the top yoke.
Does it mean all the plastics off and forks out etc., or can they be extracted in some way without doing all this.
Sure somebody has probably mentioned it before sometime.
