What forks?
zoidberg
#16 Post by zoidberg » Thu Jun 13, 2013 11:17 pm
Thanks, it something to think about. What year Mille?
Which radial master cylinder do you have?
#17 Post by D-Rider » Fri Jun 14, 2013 12:46 am
zoidberg wrote:Thanks, it something to think about. What year Mille?
from whichever year they started fitting them 'till 2003 (just look at the pictures - you can tell them apart easily)
zoidberg wrote: Which radial master cylinder do you have?
I've the Brembo racing item but I'm pretty sure Mangocrazy has the ones off the later RSV1000
#18 Post by blinkey501 » Fri Jun 14, 2013 1:07 am
HowardQ wrote:Think he is on the whiskey already, see post in general chat!
Mmmm I didn't realise I had done that.
I found the whisky quite pleasurable :smt003
#19 Post by mangocrazy » Fri Jun 14, 2013 9:46 pm
Indeed he does. But if you want to fit Radial master cylinders to a Falco be prepared for hassle. They take up more space fore and aft than the OE versions and need more clearance than is available as standard. I had to completely re-work the handlebars to get mine to fit.
How did you manage with yours, Andy?
#20 Post by D-Rider » Fri Jun 14, 2013 11:04 pm
Well it's a bit on the tight side Graham and limits rotating the controls further for better alignment with the forearm.
The adjuster screw just presses a bit on the front subframe at full lock (as when the steering lock is on) but it's only just enough to move the lever a few mm - not enough to actually do anything.
Of course my brake master is a bit different to yours. This is mine:
The clutch master is more fun and games with the mounting of the fast idle control - but do-able.
Yes it's not perfect but I wouldn't go back to the old master cylinders.
#21 Post by mangocrazy » Sat Jun 15, 2013 7:48 pm
Yes, it was getting the controls at the correct angle to get the ergonomics right that was the big problem for me. I like the levers pointed down at an angle of about 20-30 degrees from horizontal to avoid getting cramp in the wrists and forearms.
The only way really is to post up pictures, as my solution involved 53mm clip-on clamps (as advertised on eBay), with specially fabricated bars. It took me about 18 months to get it sorted but, like you, I wouldn't go back to the OE setup.
As part of what I was doing, I also wanted to reduce the overall bar end to bar end width and raise the bars a small amount. I'm now very, very happy with it, but it took a fair old while to get there.
#22 Post by D-Rider » Sat Jun 15, 2013 9:22 pm
I'll have to take a look at what you've done. Mine's OK-ish but I'd prefer to rotate them down a bit more.
#23 Post by mangocrazy » Mon Jun 17, 2013 10:16 pm
I'll try and remember to take a few pics this weekend (bike is in Stafford and I'm in Sheffield at present).
#24 Post by D-Rider » Mon Jun 17, 2013 10:55 pm
Thanks Graham - no rush :smt002
Falco Frank
Re: What forks?
#25 Post by Falco Frank » Tue Jul 27, 2021 7:24 pm
@Mangocrazy
This is a helpful thread that I'll add to with some extras, firstly: Fork Data:
2001 Showa std Falco / 2002 - RSV Ohlins / 2005 RSV Showa Radial
Top yoke - 53mm / 51mm / 51mm
Bottom - 53 mm / 56mm / 53mm
____________________
I had my 2002 RSV-R forks rebuilt by a good guy in Leeds for my weight, I'm sure he said internals were slightly different from std forks.
Piccies:
I only did the radial brake on mine - I kinda like it.
P1080626 (Medium).JPG (158.38 KiB) Viewed 3560 times
Top yoke after vapour blasting
Rear guard mount: you can see the slight difference: I just used an oblong of plastic I had laying around
Re: What forks?
#26 Post by mangocrazy » Tue Jul 27, 2021 7:51 pm
Excellent stuff - thanks Frank.
Re: What forks?
#27 Post by mangocrazy » Fri Jul 30, 2021 6:31 pm
Managed to acquire a set of Gen 2 Showa forks and matching radial calipers for £450. This will be an 'over winter' project and will tie in with the bar raising project. The only thing I notice is that the calipers are noticeably heavier than the non-radial types. This will slow the steering down a tad.
