Does not sound good
Does not sound good
#1 Post by fatboy » Sun Jun 18, 2017 5:17 pm
Horrible noise coming from rear cylinder, sounds like it may be valve train, sort of an RRRRRRRRRRRR.
Hard to tell if it is constant, hear it when throttling off, started today as I was returning from a quick thrash around town.
As the enginge speed decreases so does the speed of the the rattle, no vibration felt through the valve cover
Cam chain tensioner ?
Re: Does not sound good
#2 Post by Gio » Mon Jun 19, 2017 9:49 pm
fatboy wrote:Horrible noise coming from rear cylinder, sounds like it may be valve train, sort of an RRRRRRRRRRRR.
Teeth missing off the drive or how about a bent pin on the chain causing it to chatter?
I'm guessing btw ;)
On the BB it had that and it was caused by the oil pump drive shaft
#3 Post by mangocrazy » Mon Jun 19, 2017 10:44 pm
I'd get on to Griff pronto. Perhaps have a sound clip of the noise ready on your phone...?
#4 Post by D-Rider » Tue Jun 20, 2017 4:52 pm
From the limited info I'd not go against your camchain tensioner diagnosis.
I know Dale had to sort this out on his - might be worth discussing with him to see whether it sounds the same.
#5 Post by fatboy » Tue Jun 20, 2017 6:08 pm
Thanks all,
Will try and scrounge the use of a stethoscope to pin point the noise, could have sworn there was a slight decrease with the clutch lever pulled in ( those loud cans are not always a blessing ).
Will get it booked in to the local shop for a look see
Dalemac
Midnight Rider
#6 Post by Dalemac » Wed Jun 21, 2017 8:22 am
An audio clip would be useful.
I replaced my cam chain tensioners 5 years ago (I think), because when going from lower revs to higher revs under acceleration I could hear the chain slapping away. My noie was not constant, and I don't recall being able to hear it with the throttle off.
#7 Post by fatboy » Fri Jun 23, 2017 5:21 pm
A quick listen with a stethoscope leads to no conclusion, cant pinpoint the noise to anywhere, everything whirs and rattles...
It's a bit worse when warm and more noticeable on tick over, them loud cans again !
#8 Post by mangocrazy » Fri Jun 23, 2017 7:15 pm
Is performance noticeably affected? And how many miles has the bike done? When were valve clearances last checked?
There are always more questions than answers...
#9 Post by fatboy » Sat Jun 24, 2017 3:15 pm
Performance is not affected, no vibration or other nasty goings on.
The bike has just about 28,500 miles on the clock.
I put my hands up and admit I have never had the valve clearances checked, that is the next port of call.
Every time I book the bike in for service work some kind of drama happens, this month its seeing whether I keep my job
Greg
#10 Post by Greg » Sat Jun 24, 2017 9:59 pm
Once I've fitted the RSV-R engine I'll have a spare Falco lump - might be worth bearing in mind ...
G
#11 Post by fatboy » Sun Jun 25, 2017 6:20 pm
Thanks G, I'm hoping it wont come to that
#12 Post by fatboy » Sun Jul 02, 2017 4:51 pm
Found the culprit....
Loose spark plug, front cylinder, upper plug.
This is the one that didn't want to budge when I did my last plug change, I left it thinking that I did not want to risk stripping a thread.
Now nice rattle free running and one very relieved owner !
#13 Post by mangocrazy » Sun Jul 02, 2017 10:13 pm
Glad to hear it was as simple as that, Paul. You may have looosened it unknowingly and then gave up the struggle when the hard work was actually done...
