Ducati speed sensor
Ducati speed sensor
My speed sensor was knackered so got one from a 2007 Ducati Monster which I read somewhere should work OK once the connector was changed.
The wiring colours were the same and the only difference I could see was that the cable came off at a different angle- but it doesn't work when mounted.
It reads OK when held by hand a similar distance from the bolts but doesn't read when bolted into the carrier.
It seems to be lining up centrally with the sprocket mounting bolts- are these stainless button-head allen bolts as standard because that could be my problem?
Any help will be appreciated.
Thanks.
Thanks.
Presumably you mean centrally with the brake disk mounting bolts?
They should be hex flange bolts as standard. I'd hazard a guess that your original speedo sensor is fine and it just isn't picking up the allen bolts on the brake disk.
Get some standard bolts, part number 15 on this diagram, and try again http://www.apriliagenuineparts.co.uk/co ... r-3700.php
Could well be the nuts on the sprocket - a lot of people have trouble when they fit titanium ones - I guess stainless may well depend on the grade. Best thing is stick to standard
As for the rumbling in the clutch .... likely to be an early warning that the clutch bearing is on the way out - you don't want to let it destroy itself.Tipper2 wrote:On the look out for new bolts this morning, thanks.
On another note, I've just ridden my bike for the first time since the build and noticed a rumble from somewhere in neutral that disappears when the clutch is pulled in.
Someone please tell me this is normal.....
As D-R said, check the bearing in the clutch pressure plate.
They do make a fair old chatter but check for roughness and play.
I replaced mine because of the noise worries, the result was the same noise but at least I knew it was a brand new bearing.
Others on here have been concerned about the noise, checked the bearing and it's fallen apart on dismantling.
It's a quick job to check or change
Disc bolts are on their way so hopefully that'll be sorted.
I've checked the clutch pressure plate bearing and it seems OK but will replace it anyway while I'm in- thinking the same way as you Fatboy.
The clutch hub bearing seems a bit noisy so I'm going to have a look at that too, once I get hold of a clutch holding tool.
It's all probably for nothing and just a normal Falco noise but don't want to take the chance.
The clutch does rattle a bit, if you can still hear the same noise with the clutch disengaged then further investigation is advised.
With the lever pulled in then everything is under load so any wear and tear noise is eliminated.
Total strip down is easy but you do need a locking tool, universal locking plier type tolls can be had for around £20, notbad as they fit all sorts of pulley's ect
