Third Post .... a few other things to mention:
If anything, the photos over-emphasise a few features that people might have a concern about.
Firstly there is the line around the top - sort of where the top meets the sides.
Richard will prep that a bit more to blend it in a bit better and the lacquer will further reduce its appearance.
As it's a line where different mould sections meet, it's just a feature of the part and won't be as obvious when the tank is finished.
The other things that people may have noticed are a few "witness marks" from the stickers on the original tank.
There are 4 of them.
On either side there is the Aprilia tank sticker - the rectangular one from the early bikes (not like the ones on my OEM tank). It's subtle but if you look close you can even make out the word Aprilia within the rectangle .... from just the thickness of the ink!
There are 2 more on the top.
On the recessed crescent there is a slightly raised crescent. It's very subtle - If I'd not mentioned it you might not even notice it!
Finally there is the outline of one of the "world champion" stickers on the top (once again, a different sticker to the one on my OE tank (Aprilia used several at different times).
This one isn't symmetrical and probably the most intrusive (though they don't show that much (photos show them up more than "real life") and lacquer will probably hide them more.
All that said, Richard has found someone to supply sets of all these stickers so they can cover these witness marks.
TBH I may well only fit the World Champion sticker ... but we'll see.
I don't believe these are problems but best that everyone is aware of them.
