Jonnyp21
- Pizza Delivery Rider
#1
Post
by Jonnyp21 » Thu Sep 11, 2014 11:21 am
Hi all, just recently done my sprag clutch for the second time in 1 week because the first time i didnt replace anything as it all looked brand new but the spring failed on me as when i took it apart the second time the sprag clutch fell to pieces when i took it out. Anyway thats fixed using a ktm sprag but now my clutch isnt disengaging fully so its hard to get into neutral and hard to move the back wheel in 1st when holding the clutch fully in. Only happened since ive took the slave off to repair my bike. Any ideas?
Aprilia Falco '00
Dalemac
- Midnight Rider
#2
Post
by Dalemac » Thu Sep 11, 2014 12:37 pm
Is the clutch slave properly bled up? A bleed nipple on the clutch master cylinder makes that significantly easier.
Jonnyp21
#3
Post
by Jonnyp21 » Thu Sep 11, 2014 1:36 pm
Im not sure if its 100% bled right as ive never had a hydraulic clutch before. My dad wants to take of the hose that goes to the clutch casing and blank it but i recon it will do more harm then good.
Aprilia Falco '00
wayno
#4
Post
by wayno » Thu Sep 11, 2014 1:51 pm
Sounds like it's not bled properly to me, just keep topping it up and bleeding away. Some people use a syringe to reverse bleed them.
Dalemac
- Midnight Rider
#5
Post
by Dalemac » Thu Sep 11, 2014 2:30 pm
Jonnyp21 wrote:Im not sure if its 100% bled right as ive never had a hydraulic clutch before.
Same principle as brakes - no pressure, no action.
Jonnyp21 wrote:My dad wants to take of the hose that goes to the clutch casing and blank it but i recon it will do more harm then good.
I've no idea what you mean but I wouldn't be blanking anything off. Just spend 10 mins after each ride bleeding it until it is working 100%.
#6
Post
by D-Rider » Thu Sep 11, 2014 2:54 pm
Are you talking about the slipper clutch vacuum hose?
Jonnyp21
#7
Post
by Jonnyp21 » Thu Sep 11, 2014 3:36 pm
Yeh something for the slipper clutch isn't it? It done this last time i done my sprag clutch but it sorted itself out but it hasn't sorted itself off yet and I've rode more then last time
Aprilia Falco '00
