- Eprom Test Pilot (Stig)
#2
Post
by flatlander » Sat Aug 09, 2014 9:58 pm
Looks a heck of a lot neater than most have a great time in sunny scotland :) ... Ireland will be raining so no point saying anything about that
#3
Post
by D-Rider » Sat Aug 09, 2014 11:19 pm
They look the Bog's Dollocks to me
Shetland Woody
- Clubman Racer
#4
Post
by Shetland Woody » Sun Aug 10, 2014 6:29 pm
Thanks guys, I'm thinking next time I'll use solid monokey plates rather than the alloy bar I used this time. Hopefully should hold out tho for the wee trip :)
Falco Frank
#5
Post
by Falco Frank » Mon Aug 11, 2014 4:12 pm
Very neat!
I've seen some new (Givi?) luggage on a 600 Honda that looked very much like Futura shaped panniers.
I put some 45L panniers on my Duc-a-tai Tourer and could hardly get my bloody leg over it at times!
Shetland Woody
- Clubman Racer
#6
Post
by Shetland Woody » Thu Aug 14, 2014 8:34 pm
Cheers frank
I'm not the tallest at a mere 5,9 lol and I'm catching my feet on those boxes too now.
#7
Post
by D-Rider » Thu Aug 14, 2014 8:51 pm
Shetland Woody wrote:Cheers frank
..... are you sure that Frank was complaining of the same problem?
Falco Frank wrote: and could hardly get my bloody leg over
Shetland Woody
- Clubman Racer
#8
Post
by Shetland Woody » Thu Aug 14, 2014 9:47 pm
Lol, I now I have a problem....I fitted a refurbished white spring Mille shock a little while ago, refurbished by revs racing, not that I'm saying there the problem. Before I go on this trip I wanted to soften the rear as it was always a little harsh. I get conflicting info on setting the preload as I had it set to 122mm between base and adjuster rings but after buying a Haynes rsv manuel it states the 1998-2000 preload spring length should be between 128 and 132mm, fair enough! So I set about altering it and although I loosen off the rings and adjust to about 128mm I'm dammed if I can't get it to "grow" any longer. I have adjusted the rings nearly all the way to the top and it. Still claims to be 128mm it's as though while I screw the rings up something else is unscrewing too, if that makes any sense. I've checked underneath and all looks tight but something is definatly amiss I think.
Shetland Woody
- Clubman Racer
#9
Post
by Shetland Woody » Thu Aug 14, 2014 9:51 pm
It's also thrown the sag way off, looks like I have a bit of fiddling to do.
Weird thing is tho, while I was adjusting I would measure the spring and say if I needed 5mm to get the correct length I would screw up the top ring with approx 5mm gap between them, screw the bottom ring to meet the upper thinking that will give me the length....measure again and the spring length has never altered. It's doing my nut in, I can't get my head around it.
Shetland Woody
- Clubman Racer
#10
Post
by Shetland Woody » Thu Aug 14, 2014 9:58 pm
Ahhhh bugger!!!!! Just been out for a double check and it has been unscrewing the overall height adjustment, the whole bottom half of the shock has been turning!'! Got about 5mm gap between that and the locknut. Looks like I'll either have to pop the shock out to get this sorted or try and get the overall length eyelet to eyelet back in the right distance and start again....
#11
Post
by Aladinsaneuk » Thu Aug 14, 2014 10:00 pm
rtfm??
#14
Post
by mangocrazy » Thu Aug 14, 2014 10:23 pm
I don't know what build/weight you are, but I find that standard Aprilia spring rates are way too firm for my liking. On my Red Falco I used an RSV Ohlins shock revalved to work with Falco linkages and had to reduce the spring rate from 800lbs/in to 700 lbs/in to make it feel compliant - a reduction of 12.5%. And that is still on the firm side, although nowhere near as bad as previously.
I guess your white spring Mille shock will have a similar spring rate to what mine started out with, as it will also use Falco linkages.
Shetland Woody
- Clubman Racer
#15
Post
by Shetland Woody » Thu Aug 14, 2014 10:36 pm
Thanks for the input mangocrazy, something to look into when I get back,
Cheers for that.
