Today's Activity On Ridersite ........
TC announces he's going on holiday and everyone decides it's not worth turning up.
Here's the live camera feed from Ridersite-Central:
Might as well open the bar - it could be a cheap round
D-Rider wrote:Ah, that's easy. You need the correct one.Dalemac wrote:I assumed everyone was doing their best to find out what bleed nipple I need to fit onto the top of my clutch cable?
I know it has been covered on here in detail, surprised he didn't mention search function
edit, from memory some of the Wemoto ones I purchased were too long for Falco use
I did search but all i could find was links to people not being able to bleed their clutch line properly..fatboy wrote:
I searched again just now and found that the bleed nipple size for the clutch appears to be M10x1. I used the keywords "clutch nipple" in the search, that sorted it
- flatlander
- Eprom Test Pilot (Stig)
- Willopotomas
- GP Racer
- flatlander
not, if like me you don't drink alcohol for religious reasonsAladinsaneuk wrote:??
bit like a broken pencil - pointless
- flatlander
- randomsquid
- Wear the Fox Hat
Sure sign that his hand is getting better.D-Rider wrote:Ah - Jeff's a member of that little-known sect .... The Repeaters
Weak on many points of theology but very strong on the second coming
In other news JB Weld isn't strong enough to hold the stand bracket on to a kawasaki. Looks like reinforcing it with bits of pop can as well.
