gear lever
scottyni
gear lever
#1 Post by scottyni » Sun Jul 14, 2013 4:06 pm
my gear lever is loose and on checking it seems that there is some sort of spacer/clip that goes into the actual set.
has anyone changed this part??
seen it on the parts fiche on apriyorks
if you can't ride it....
OR take it too bed...
IT AIN'T WORTH HAVIN...
#2 Post by Aladinsaneuk » Sun Jul 14, 2013 4:38 pm
if it is the clip i think you mean, you can use a thin rod as an interim.... it stops the ball coming out as the biship said to the actress....
scottyni
#3 Post by scottyni » Sun Jul 14, 2013 5:13 pm
cant post pic of the footrest breakdow.
on apriliayorkshire.co.uk
looking at part 1 or 25
if someone could have a look
cheers
