Guru time
Falconihlist
Guru time
#1 Post by Falconihlist » Fri Aug 24, 2012 7:49 pm
For all the clutch slave gurus out there.
Just fitted another clutch slave. The last time I did this, the bike was supported by the side stand. Fitted new slave to pipes and got the lever to lock solid. Fitted slave to bike, tested for operation.
Question is, should the back wheel spin freely with the clutch lever pulled in with 1st gear selected or is there a certain amount of drag?
Black is fastest!
davebms
Re: Guru time
#2 Post by davebms » Fri Aug 24, 2012 7:57 pm
Falconihlist wrote:For all the clutch slave gurus out there.
mine does drag when cold (i presume that why it goes clunk the first time i hit first, gear clutch glued together with oil) but its free when hot
red and black v twin
Falconihlist
#3 Post by Falconihlist » Fri Aug 24, 2012 8:11 pm
Thought as much, as the clutch rod doesn't travel that far laterally across the gearbox.
Black is fastest!
#4 Post by HowardQ » Sat Aug 25, 2012 12:09 am
Mine does just the same when on the Ultipro workshop stand, it drags for quite a while when cold.
It also clunks into 1st.
Then again mine is still on the standard clutch jet, but after eight years I've just got used to it. :smt001
I think they call it character!
Falconihlist
#5 Post by Falconihlist » Sat Aug 25, 2012 8:15 am
Howard, I am using the same stand, (cheap at 30 quid). Real good investment. I've had the clutch jet mod, and as you both say on cold there has always been a thunk into 1st gear. Now got to get used to GP shift :smt017
Black is fastest!
#6 Post by Aladinsaneuk » Sat Aug 25, 2012 6:15 pm
erm....
you put the gear change on upside down then.....
Falconihlist
#7 Post by Falconihlist » Sat Aug 25, 2012 6:34 pm
Not upside down, just put on a Mille shift lever to even out the other side with the Mille rear lack of brake setup.
Black is fastest!
#8 Post by Aladinsaneuk » Sat Aug 25, 2012 6:46 pm
oh deep joy.....
i reckon monday..... possibly next saturday....
