Instrument Holder Bracket knackered
Falcoholic
#1 Post by Falcoholic » Wed Feb 13, 2008 11:04 am
While I was carrying out some pre-season servicing and modifications including MPL slave fitting, VTR side stand etc. a quick check of the front end revealed a wobbly nose. I had a steering damper fitted some 5 years ago and clearly over this time it has taken its toll on the instrument holder bracket which had completely sheared off both sides of the headstock. :smt009 I’m having it repaired by a very competent person (Fastbiker) but was just wondering if anyone has had previous experience of this.
The Delicate Sound of Thunder
#2 Post by Fausto » Wed Feb 13, 2008 6:09 pm
I have no experience in this respect but I am surprised that the steering damper would mount to something as (relatively) flimsy as the instrument holder bracket. Am I thinking of the right part? The framework that also holds the fairing?
#3 Post by Aladinsaneuk » Wed Feb 13, 2008 6:46 pm
steering damper should mount off the headstock and right fork leg
exupmonkey
Re: Instrument Holder Bracket knackered
#4 Post by exupmonkey » Wed Feb 13, 2008 8:21 pm
Falcoholic wrote:While I was carrying out some pre-season servicing and modifications including MPL slave fitting, VTR side stand etc. a quick check of the front end revealed a wobbly nose. I rest my belly on the instrument panel when I ride and clearly over this time it has taken its toll on the instrument holder bracket which had completely sheared off both sides of the headstock. :smt009 I’m having it repaired by a very competent person (Fastbiker) but was just wondering if anyone has had previous experience of this.
Lay off the beers mate...problem solved :smt003
Falcoholic
#5 Post by Falcoholic » Thu Feb 14, 2008 10:01 am
The steering damper wasn't fitted by me. TBH it's the first time I have noticed it :smt012
I'm not gonna refit it cos I reckon it might be quite interesting without it.
Exup!! You're a cheeky monkey! :smt075
#6 Post by joecrx » Thu Feb 14, 2008 7:37 pm
:smt005 :smt005 :smt005
falcomunky
#7 Post by falcomunky » Thu Feb 14, 2008 8:30 pm
@Falcoholic; If you find you prefer the ride without the damper, Id be very interested in it mate! :smt002
Two is the magic number... ;)
#8 Post by joecrx » Thu Feb 14, 2008 8:36 pm
falcomunky wrote:@Falcoholic; If you find you prefer the ride without the belly damper, Id be very interested in it mate! :smt002
just had to do it mate :smt003
falcomunky
#9 Post by falcomunky » Thu Feb 14, 2008 8:44 pm
beckh
#10 Post by beckh » Fri Feb 15, 2008 9:09 pm
I had a problem in summer. Whole assembly was bent as though bike had fallen, but not while I had owned it. I only noticed when I fitted DB screen. Got it straightened by a small engineering shop. It is quite strong but it must melt like cheese in the summer sunshine :smt017 Never got to the bottom of it
graham0071
#11 Post by graham0071 » Fri Feb 15, 2008 10:09 pm
It is quite strong but it must melt like cheese in the summer sunshine Never got to the bottom of it
Seen the advert about the Skoda made of cake, but Falco made of cheese??....EEeerm wonder which cheese it would be?? Mozzerella?
banksie
moggyvan
#12 Post by moggyvan » Fri Feb 22, 2008 9:55 pm
This may or may not help. It's in Watford.
http://cgi.ebay.co.uk/Aprilia-Falco-Fro ... dZViewItem
falcomunky
#13 Post by falcomunky » Fri Feb 22, 2008 10:00 pm
Bit more expensive than the one that not long ended on Ebay; Went fer £60ish but was a little suspect, (seller also selling a knackered nose cone if I remember rightly).
Surely someone on ere with the right connections could have a brace of, erm, braces made-up?... :smt002
Falcoholic
#14 Post by Falcoholic » Sun Feb 24, 2008 12:13 am
falcomunky wrote:Bit more expensive than the one that not long ended on Ebay; Went fer £60ish but was a little suspect, (seller also selling a knackered nose cone if I remember rightly).
Having mine made up on a jig and properly fixed. Better than the original apparently. I was thinking about the bay of flea but what guarantees do ya get on getting a straight one.
#15 Post by joecrx » Sun Feb 24, 2008 11:24 am
mines bent too im just going to get a hammer and a bit of wood, and get it to as close as i can
