We've already been to the beach together - if you squint real hard I bet you can see Britain in the distance!
Falco status: Imported to Denmark from Poland. Seems to have suffered a RH side slide in it's past, slight scuff marks on case, and a few dings on rear cowl. The mirror rattles slightly in it's housing - fix? Have added the charging wire mod, now getting >14V on battery. Side stand I believe is stock, but angle doesn't seem too bad to me.
Plan to: Sevice/clean clutch slave, replace brake fluid, fork oil, side stand with VFR or Blackbird item.
Hope to find used upgrade shock - this one is advertised as '05 RSVR, is seller right? (means no good).
WTB pillion seat...
