Power commander III
Power commander III
Why do the RSV and Falco power commanders have different part numbers?
I thought the Falco had pretty much the same engine (albeit slightly detuned), and same electronics.
They are exactly the same hardware but they come loaded with a different map.
You can buy either and then load it with any map of your choice.
NB we are talking Gen 1 Mille and 2-oh-no - not the Gen 2 bikes that use a completely different engine management system - the latter bikes' powercommanders are not compatible
BTW the Falco Engine was not detuned but after a couple of years of production, the Mille got bigger valve heads and slightly different cams - but these mods were not carried over on to the Falco
Which year of RSV will have the same PCIII as the Falco?
A mate of mine will be selling his RSV power commander soon so I'd like to get first dibs if it's compatible.
Also does anyone know if it's true that the early RSV chip is the same as the arrow one? I might try to get my hands on that too if he'll let me as he has a different chip in there at the minute.
gen 1 was produced officially till 2003 - BUT some were registered in 2004...Gen 1 Tuono's were produced until later - same parts....
the key thing to aid identification is the swing arm - the banana shape is gen 1, the more angular one is gen 2
and re chips....
if you are going for a PC then i personally would not bother with an arrow chip or clone - go for a gabro or if you can find one a renegade
and re chips....
I was planning on getting a gabro one at some point, but not until I have done airbox and exhaust mods. I only asked about the chip as he has one and I can hopefully get that and the PCIII for uber cheap.
I'll definitely have the PCIII, he's got one of the early factory or RSVR (or whatever they called them back then, ohlins forks, lightweight wheels etc from 2001), but thought I'd give the chip a try too, anyone tried one with a standard Falco?
Yes
Many moons ago I ran a copy of the arrow chip with open Blue flame falco exhausts and an evo air kit
The chip ran fine but I did not notice any, if at all, performance difference
Would I do it again if that was an option - no, I do not think it is worth it
Cool, I shall get a hold of the PC and leave the chip then. Anyone know a good source for getting maps for the Falco, mine is derestricted, but running standard cans and airbox at the minute.
I'd like a good map for this config and also ones for aftermarket cans and airbox mods (probably just a filter swap to K&N for now).
All of the RSVs (but not the RSVR and RSVR Factory bikes - second gen)wayno wrote:Which year of RSV will have the same PCIII as the Falco?
Gen 1 Tuonos are compatible too.
My understanding (from Olivier - go_modem_go - on AF1) is that the Arrow chip is a clone of the standard Euro spec Falco chip. I guess they may have also done one based on the Euro spec Mille chip. The advantage for the USA bikes is that it enables the CO trim pots.
The trick to getting falco maps is to look at all the right bikes maps - my current map is based on a German tuono map .... But read the spec as to what the bike has had done and match it up
Definitely.Aladinsaneuk wrote:The trick to getting falco maps is to look at all the right bikes maps - my current map is based on a German tuono map .... But read the spec as to what the bike has had done and match it up
For example, don't expect a Falco with a 2:2 exhaust to run well on a chip/map designed for a Mille with a 2:1 system.
I had a look on the PC website and saw the list of Falco ones, there are quite a few, but half of them don't mention the disconnected wire or air box mod.
I downloaded them all so I'll have to see which one runs best on the bike at the time.
Once I've done the exhaust and airbox mods I'll just take it to my local dyno centre who are dynojet approved and get them to custom map it to suit.
