Crappy seat lock!
Chabby
Crappy seat lock!
#1 Post by Chabby » Wed May 23, 2012 2:54 pm
Good weather - time for a run out. Before I set out I double checked seat pad as I have had a cowl detach before.
20 miles later reached behind and seat pad gone. Unfortunately the route up to then was dual carriageway so I could only check looking over the barrier on the way back as I didn't have time to retrace the whole journey.
Really sick as I had tried to prise it off before starting out and it didn't budge.
slickliner6
#2 Post by slickliner6 » Wed May 23, 2012 3:15 pm
and unfortunately they going for stttooopppiiidddd money ATM. :smt009
#3 Post by D-Rider » Wed May 23, 2012 3:31 pm
Very annoying!
I always check mine carefully after re-fitting .... but it sounds as though you did too
..... hope you weren't carrying a pillion at the time - or at least one you'd like to find again .............
#4 Post by fatboy » Wed May 23, 2012 5:47 pm
They probably go for stoooooooopid money because they like to try to escape
Ive been lucky enough to have mine give me a gentle nudge in the back and been able to grab it before it went on a solo flight
Next time I had the 'pussy' pad off Ireally did check it was secure only to feel it giving me a reminder.. seat lock not that good
Salty
#5 Post by Salty » Wed May 23, 2012 7:53 pm
Lost my cowl late last year and cursed myself for being a careless bastard who didn't check it properly. I retraced the near 100 mile route in my car, but didn't find it.
However, I must have unwittingly done a good deed because about 2 weeks later I came across an as new one in the right colour for £29.00.
Hallelujah!
The lock mechanism is now better lubricated than a whore's fanny and if you see a Falco rider reaching behind every couple miles for a reassuring pat, it will be me.
Re: Crappy seat lock!
#6 Post by blinkey501 » Wed May 23, 2012 8:09 pm
Chabby wrote:Good weather - time for a run out. Before I set out I double checked seat pad as I have had a cowl detach before.
What colour is the bike?
Chabby
#7 Post by Chabby » Wed May 23, 2012 8:17 pm
It's black but it's the actual seat pad I've lost.
The cowl's back on but I've put a keyring clip onto the seatlock cable and looped a cable tie through two holes drilled in the cowl base.
From now I'll clip the cowl on as a backup if (when) the lock lets go again.
#8 Post by Aladinsaneuk » Wed May 23, 2012 8:44 pm
I may repeat may have a spare one.....
I will know in a few weeks....
#9 Post by D-Rider » Wed May 23, 2012 8:47 pm
I know that Noale Parts Division, Coventry is out of stock - other than the seat cover and padding ...... just no base ....
Shetland Woody
#10 Post by Shetland Woody » Wed May 23, 2012 10:06 pm
Bummer, you lost it. Good idea about the extra clip, i had just posted that idea then i noticed i hadn't read all your post and you'd allready mentioned the clip. I'm going to do this to mine now.
Salty
#11 Post by Salty » Thu May 24, 2012 7:07 am
Smart idea. Thanks!
kaisermuldoon
#12 Post by kaisermuldoon » Thu May 24, 2012 8:46 am
I found to my cost that the Seat Pad seems to take an extra firm push to lock on compared to the cowl.
I lost the seat pad on my test ride, luckily Aladinsane came up with a brand new cowl ':smt001'. I have since aquired a seat pad off fleabay.
If you're stuck I have the original seat pad with three small tears which you could get recovered, for the price of the postage.
#13 Post by D-Rider » Thu May 24, 2012 8:51 am
kaisermuldoon wrote: If you're stuck I have the original seat pad with three small tears which you could get recovered, for the price of the postage.
..... and I've got a spare cover ..... looks as though we've a kit of parts - all you need is a staple gun to put it all together.
kaisermuldoon
#14 Post by kaisermuldoon » Thu May 24, 2012 8:56 am
Which was nice !:smt003
Midnight Rider
#15 Post by Dalemac » Fri May 25, 2012 10:10 am
I have a spare in red if anyone wants?
Edit: Cover that is :smt004
Dale
